1. dan-355's Avatar
    I have a vizio vtab 1008 running android honeycomb 3.2.1. I downloaded madden 25. It downloaded fine, then downloaded all the game data, now when try to open it it goes to a black screen then back to home screen. Any help would be appreciated. This is for my 7yr old son
    01-07-2014 11:34 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Maybe the app isn't compatible with your device. From where did you download and install? Google Play can determine if an app is incompatible, and won't let you install. However, if you downloaded the .apk installer file from some other source, then you won't necessarily know if it's compatible or not.
    01-07-2014 12:05 PM
  3. dan-355's Avatar
    i downloaded it from the google play store
    01-07-2014 01:45 PM
  4. B. Diddy's Avatar
    Have you rebooted since installing it? Give that a try.
    01-07-2014 01:52 PM
  5. dan-355's Avatar
    i tried everything reboot, uninstall, reinstall nothing at all does same thing
    01-07-2014 02:09 PM
  6. dan-355's Avatar
    i just looked at it and it says it is compatible any ideas?? Thanks
    01-07-2014 02:53 PM
  7. B. Diddy's Avatar
    Try emailing the developer at help@eamobile.com.
    01-07-2014 04:13 PM
  1. Free Beer to anyone who can help!!!
    By Kieran Donnelly in forum Google Nexus 7 Tablet (2012)
    Last Post: 01-13-2014, 04:54 AM
  2. need help
    By Asad Jan in forum HTC Amaze 4G
    Last Post: 01-12-2014, 02:41 PM
  3. Can't open images. Please need urgent help!!!
    By goku1234567890 in forum Android 2.3 Gingerbread
    Last Post: 01-07-2014, 12:55 PM
  4. Please help me
    By robertprun in forum General Help and How To
    Last Post: 01-07-2014, 11:23 AM
  5. Replies: 0
    Last Post: 01-07-2014, 10:46 AM
