1. jason6677's Avatar
    I downloaded Ditto Note 3 for my note 2, and i flashed it. It didn't work so whatever. After reading on the thread a little longer, it said i needed to flash a kernel. So after flashing ditto note 3 and the kernel i rebooted my phone to see that it was stuck on the Note 2 logo. I thought it was all fine until i booted into recovery mode to find that cwm would make my phone restart. I have backups of cm11 and stock touchwiz, can i flash them with odin?(im sorry if this is a stupid assumption, i started roms yesterday). Can I go into my storage and take them out? Well, I'm beginning to give up because i spent a whole two hours trying to do this now. So basically, my phone is bootlooping and cwm isnt working. Please help, somebody.
    01-07-2014 09:02 PM
  2. srkmagnus's Avatar
    You can't flash the backups with Odin. You'll have to use recovery to restore those files. What you can do is try and flash a working Kernel with Odin (it should have cwm as well) and boot to recovery. Try and restore the backup that way and see what if you can get back up and running.
    01-07-2014 09:32 PM
  3. jason6677's Avatar
    I flashed twrp and the only rom i had was ditto so i gave it a go. AND IT ACTUALLY WORKED. Wow and I thought i lost my phone, guess i learned my lesson not to install wrong device roms again
    01-07-2014 10:53 PM
  1. Phone Data Not Syncing
    By Masheen in forum Motorola Droid MAXX
    Last Post: 01-15-2014, 01:47 PM
  2. Update Bricked my Phone :(
    By Worlds2See in forum Verizon Galaxy S III
    Last Post: 01-11-2014, 06:37 PM
  3. Who's Using the Nexus 5 to Cover CES?
    By Scott7217 in forum Google Nexus 5
    Last Post: 01-10-2014, 10:11 PM
  4. Can the keyboard be resized?
    By jdbii in forum Moto X (2013)
    Last Post: 01-07-2014, 09:05 PM
  5. Note 10.1 2014 - Adjust the height of hand writing area
    By ChengYeng L in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-07-2014, 08:28 PM
