Results 1 to 4 of 4
    indaglop's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How to transfer data between devices?
    Hey
    Hope this is the right subforum for my question...
    I've alread read a number of tutorials and threads on this topic, but I'm still confused. Maybe I can get some help here.
    The goal: data migration from my Nexus 4 to my Nexus 5.
    The problem: Other than the Google apps that can be re-installed with previous user data, all other apps lack my previous data when installed on my new phone.
    The details: My phone isn't rooted, and I'd prefer to find a solution that doesn't require rooting. I've already tried the often recommended app MyBackup Pro, however it looks like it only makes a backup (and restores) the app, without the user data, on an unrooted phone.
    My question: Any recommendation how to achieve the goal? Did anyone try the "Helium" app. Does it do what I want to, copy the user data along?
    Alternatively, I read somewhere that you can make a complete backup of your phone's storage through the ADK. Would that be helpful in my case?
    Last remark: Ideally I would copy *all* user data over to my new phone, but if that's not realistic/too much hassle, the data that I would *really* hate to lose is the following: my old SMS and my old Whatsapp conversations. So if there's a more narrow solution only for those two items, I'd still like to hear it.
  2. Best Answer
    Quote Originally Posted by indaglop View Post
    Hey again
    I waited two days, so I hope it's okay that I give it one bump now:
    Can anyone help me with my question?
    Welcome! Thanks for being patient while waiting for an answer. I have no used Helium, but would suggest it as a lot of people with unrooted devices have had success with it. You do need to have a computer to use alongside the App since you are not rooted - this is how it will make a backup of the Apps, with data, and install to your new phone.
    It should also be able to copy your sms and same with WhatsApp, provided WhatsApp saves the data within the App. Take a look at Helium and see if it's something you can use: ClockworkMod Carbon & Helium - Google Play Store.
    Let us know if you have any questions!
    Edit: The App used to be called Carbon, so ignore the title on the first link as it's actually Helium.
  3. Thread Author  Thread Author    #2
    indaglop's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Any chance I can get some help with data migration from one Android device to another?
    Hey again
  4. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    13,759 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Hey again
  5. Thread Author  Thread Author    #4
    indaglop's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey. Thanks for your answer.
    I tried Helium (formerly: Carbon), and at the risk of sounding like fanboy... It works! It actually works!!!
    Seriously, after so many attempts I really didn't expect that. None of the other solutions worked on my unrooted phones, but Helium does. Huge relieve, really... Data migration finally underway.
    Thanks again for the recommendation.
  1. Which seems better to buy
    By vdyaulaw in forum General News & Discussion
    Last Post: 01-21-2014, 02:56 AM
  2. Should I disable data to conserve data usage and battery?
    By Tara100 in forum General Help and How To
    Last Post: 01-10-2014, 07:35 PM
  3. Microsoft Exchange Calendar to Google Calendar on N5
    By alibumaye in forum Google Nexus 5
    Last Post: 01-09-2014, 12:33 PM
  4. Trouble With Full Screen Ads?
    By bgoldenberg94 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-09-2014, 10:06 AM
  5. Problem with camera
    By fml12 in forum Samsung Galaxy S4
    Last Post: 01-08-2014, 11:24 AM
