Results 1 to 3 of 3
Like Tree2Likes
  • 1 Post By Golfdriver97
  • 1 Post By B. Diddy
    cgm707's Avatar
    Posts
    Global Posts
    18 Global Posts
    Question Calendars - aaaargh!
    Just when I thought I had it figured out.....After many trials and errors, I have ascertained that it is the iCloud calendar that should show up on all devices (Macbook, iPad, and android phone), or at least, that is what I thought. I have a Samsung Galaxy S3 phone, and it is not showing entries that I have on my iCloud calendar. Under Preferences/Calendars, I see Gmail calendars, Samsung calendars, "My Calendar" .... are any of these the iCloud calendar, or, is there an option to add the iCloud calendar?
    I am just trying to have the same info on all my devices' calendars....
    Thanks for any help.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,753 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Calendars - aaaargh!
    Apple does not play well with Android. If you can, try seeing if you can transfer your events to Gmail. That will sync to Android.
    B. Diddy likes this.
  3. #3
    Here's an app that can sync your iCloud calendar with your Android device: SmoothSync for Cloud
    If you just want to move all of your iCloud calendar events to Google, you could simply export your iCloud calendar following these steps: https://support.atu.edu/link/portal/...Cloud-calendar. Then follow the instructions on this support page on how to import iCalendar files to Google Calendar: https://support.google.com/calendar/answer/37118?hl=en.
    Golfdriver97 likes this.
  1. Calendar Issue
    By Sam12Ash in forum Moto X (2013)
    Last Post: 01-13-2014, 06:54 AM
  2. Microsoft Exchange Calendar to Google Calendar on N5
    By alibumaye in forum Google Nexus 5
    Last Post: 01-09-2014, 12:33 PM
  3. Calendar notifications not firing for Calendars which aren't displayed....
    By WATYF in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-07-2014, 01:06 PM
  4. Calendar importing in wrong time zone
    By Shanicenicolle in forum Samsung Galaxy S4
    Last Post: 01-07-2014, 11:24 AM
  5. Calendar issue
    Last Post: 01-06-2014, 11:15 PM
