Results 1 to 4 of 4
    Default Android TV Box doesn't turn on? please help!
    hello everyone, I bought this android tv box from ebay, and there was a weird UI and I decided to delete Launcher. so I deleted it and after it didnt get to the home screen, and then i closed it and re-opened it and then stucks in to the android silver logo and I wait but nothing happens.
    so my question is, is there a way to reset it to the factory settings though my pc or something like that? please help!
    thank you...
  2. #2
    Default Re: Android TV Box doesn't turn on? please help!
    Welcome to Android Central! The Launcher is basically the homescreen user interface, so by deleting it, you basically can't interface with the system any more. It's odd that you were actually able to delete the Launcher, because most Android devices won't let you delete system apps, unless they're rooted (i.e., modified to give you superuser status, which can be a dangerous thing, as you've learned). I'm not sure a factory reset would help at this point, because if you truly deleted/uninstalled the Launcher, it won't be restored by a factory reset. You'd have to find the original stock ROM for the device and learn how to re-flash it to the device--in order to do so, you'd need to find instructions specific to the device. I suggest doing a Google search that includes the exact brand and model name of the device, and the words "flash stock ROM." Good luck!
    well thank you very much, but I don't think I'll find it, necause it not very "famous" device :P
    never mind have a nice day and thank's again
  4. #4
    Quote Originally Posted by jixty View Post
    Just tell me the model name of the device.
  1. Replies: 9
    Last Post: 11-29-2016, 05:53 PM
  2. Replies: 50
    Last Post: 01-22-2014, 04:11 PM
  3. Suggestion on thin case for HTC One?
    By cristianocr7 in forum Verizon HTC One
    Last Post: 01-14-2014, 05:56 PM
  4. Help Me! Samsung Galaxy S2 Stuck in Bootloop
    By angelisawesome in forum T-Mobile
    Last Post: 01-10-2014, 01:41 AM
  5. VoIP app that doesn't use Google Voice for calls?
    By wildblue in forum Android Apps
    Last Post: 01-09-2014, 10:39 PM
