1. Sax_Derp's Avatar
    So I got a Nexus S for Christmas and I've been getting about 5 hours light usage off a full charge. I have mobile data off a
    nd I'm normally on Airplane mode unless I'm texting someone (which is rare...) It's running stock Jellybean 4.1.2 and I did buy a new battery but I'm still having the same issue.
    01-09-2014 07:54 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Check out this guide and see if any of the tips help you: http://forums.androidcentral.com/amb...ving-tips.html
    It'd help to see some of your battery stats, especially from a good battery monitor app like GSam Battery Monitor. When you say 5 hours of light usage, does that mean 5 hours of light usage with the screen on, or with intermittent use of the screen? 5 hours of total screen-on time is normal.
    Sax_Derp likes this.
    01-09-2014 07:56 PM
  3. Sax_Derp's Avatar
    Intermittent, I'm at school most off the day so it generally stays off in my pocket. I'm downloading that app now, is there a way I can post a screenshot from the Android Central app?
    01-09-2014 08:09 PM
  4. B. Diddy's Avatar
    Unfortunately, not from the main AC app. You can if you use the Tapatalk-based Android Central Forums app.
    01-09-2014 10:24 PM
  5. Sax_Derp's Avatar
    These are the two screenshots from the app. This was taken when I left school today. My phone did die by 10 this morning and I charged it to 21% to get through the rest of the day. I took it off the charger thus morning by around 6:18
    Sent from my Nexus S 4G using AC Forums mobile app
    Attached Thumbnails Battery Issues On a Nexus S-1389394136638.jpg   Battery Issues On a Nexus S-1389394149460.jpg
    01-10-2014 05:50 PM
  6. mrsmumbles's Avatar
    Usually battery issues are starting after installing a conflicting 3rd party app.
    Sent from my LG-LG870 using Tapatalk 2
    01-10-2014 06:15 PM
  7. B. Diddy's Avatar
    Unfortunately, those screenshots don't help that much, because GSam resets its stats when you start charging or turn off the phone. At the top of the App Sucker screen, you'll see that the stats are only for the last 18 min 13 sec, so the info isn't giving us a good representation of the whole battery charge.
    01-10-2014 06:18 PM
  8. Sax_Derp's Avatar
    So, sorry for not responding. But my issues seemed to have been resolved. I removed a few unessential widgets and let the battery fully die a few times before charging it to full again. I now get about 8 hours on a full charge and I am okay with that. Thanks for the suggestions, and yeah.
    B. Diddy likes this.
    01-13-2014 11:04 PM
  1. Samsung Galaxy S3 Mini unexplicable Battery drain
    By juandariorodas in forum Samsung Galaxy S3 Mini
    Last Post: 03-19-2016, 07:11 PM
  2. Suggestion on thin case for HTC One?
    By cristianocr7 in forum Verizon HTC One
    Last Post: 01-14-2014, 05:56 PM
  3. AT&T HTC One - Third-party keyboard issue.
    By strife5 in forum AT&T HTC One
    Last Post: 01-13-2014, 07:57 AM
  4. Replies: 8
    Last Post: 01-10-2014, 11:27 PM
  5. Android TV Box doesn't turn on? please help!
    By jixty in forum General Help and How To
    Last Post: 01-09-2014, 09:55 PM
