Results 1 to 3 of 3
    staysha921's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question PLEASE HELP?! How to unlock Galaxy Note 2
    I changed my passcode last night and can't remember what it is!!! I called Verizon they said after so many failed attempts it will prompt me for my email info. GREAT, but I'm at 150 failed attempts and it hasn't prompted me yet :-(
    PLEASE HELP!
  2. #2
    VDub2174's Avatar
    Posts
    Global Posts
    5,775 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: PLEASE HELP?! How to unlock Galaxy Note 2
    Your best bet is to probably take it to a VZW store and see what they can do.
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    If you have USB debugging enabled, you can use adb to delete the lock files. There are instructions all over the web. If not, VDub's advice is probably best. Be sure to tell them that you DON'T want the factory reset "fix". That's the fastest way to do it - if everything on the phone is backed up, or you don't care if you lose data. Boot into recovery and factory reset.
    You can also try to boot into download mode, then hit volume down to cancel, and see if it boots into a normal homescreen.
  1. How to show my number in own number status?
    By aseke in forum Samsung Galaxy Note 2
    Last Post: 01-06-2014, 10:31 PM
  2. verizon galaxy note 2 model SCH-1605 update 4.3 fails every time
    By daniel_dh in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-04-2014, 05:31 PM
  3. screen help
    By mcruz78x in forum Samsung Galaxy S3
    Last Post: 01-04-2014, 02:48 PM
  4. Replies: 7
    Last Post: 01-04-2014, 09:35 AM
  5. How to announce new application on Android Central ?
    By Paul Walker5 in forum General News & Discussion
    Last Post: 01-04-2014, 02:31 AM
