Results 1 to 7 of 7
    Default Gmail on Tesco HUDL
    Hi guys
    I am trying to get in to the General Settings page in Gmail on my Hudl to change the "swipe to delete" value, but I cannot find the page!!!
    When I go into settings there is a General link but it only shows
    - Auto advance
    - Message text size
    - Ask to show pictures
    I have tried different contexts, inbox, recycle bin, unread email, read email, but cannot find this setting, in fact according to the Google help page I am missing a whole range of settings.
    thanks in advance.
  2. #2
    Default Re: Gmail on Tesco HUDL
    Welcome to Android Central! What version of the Gmail app are you using? It just updated to 4.7.2. You are talking about the app, and not the Gmail webpage on the browser, right?
    Yes it is Gmail on android. The Gmail client is 4.7.2 (967015)
  4. #4
    Ok, just to make sure we're on the same page, you're doing the following, correct?
    1. Open Gmail app.
    2. Press Menu button (either hard menu button or 3 vertical dot soft menu button).
    3. Select Settings.
    4. Select General Settings. Do you see the Swipe To Delete option there?
    Do you think you could post a screenshot of your Gmail Settings page?
    Can't tale a screen shot at moment, but this is what I have.
    1. Open Gmail
    2. tap three dots in top right
    3.select Settings
    4.select General on new screen (other option is mail account)
    5.new screen is headed "APPLICATION" and has the following three options
    - Auto-advance
    - Message text size
    Apart from "ADD ACCOUNT" in top right there are no other tappable objects on screen and no other options
  6. #6
    Strange. I suppose it could be a device specific limitation. Does Tesco have a support page? Maybe you could speak to their support department.
    Thanks for your help, I'll see what I can come up with.
  1. Email vs Gmail Apps: Deleting an Account?
    By David Lessnau in forum Google Nexus 5
    Last Post: 05-26-2015, 02:24 PM
  2. Galaxy Note 10.1 (2014) Google Play Mags on SD
    By Soooperpigdog in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-24-2014, 11:55 AM
  3. Can't get 3G/LTE on SGIII on CM10.1 to 11
    By pknipper in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 01-22-2014, 08:27 AM
  4. Google Play Services update improves multiplayer gaming on Android
    By Shilohcane in forum Android 4.4 KitKat
    Last Post: 01-11-2014, 11:18 PM
  5. Replies: 0
    Last Post: 01-10-2014, 09:35 AM
