1. browsell85's Avatar
    In bootloader this is what comes on the screen:
    *** TAMPERED ***
    *** UNLOCKED ***
    M7_UL PVT SHIP S-ON RH
    HBOOT-1.44.0000
    RADIO-4A.14.3250.13
    OpenDSP-v26.120.274.0202
    eMMC-boot
    And also when i try to connect to pc it connects as an unknown device. Seriously need some help here.
    01-11-2014 01:44 PM
  2. aspot72's Avatar
    *** TAMPERED ***
    *** UNLOCKED ***
    HBOOT-1.44.0000
    RADIO-4A.14.3250.13
    eMMC-boot
    crappy messing...
    Reboot in normal mode and use ADB. You need to update HBOOT. Google (and XDA Devs) is your friends...
    01-11-2014 02:15 PM
  3. browsell85's Avatar
    I cant connect to my pc. it shows up as an unknown device. and it only runs in bootloader, no recovery or anything.
    01-11-2014 02:38 PM
  4. xceeder's Avatar
    Hhmm sounds a bit messed up , what was the last thing you did on your phone before it messed up can you remember??
    sent from my Nexus 7 using tapatalk pro..
    01-11-2014 03:13 PM
  5. xceeder's Avatar
    And nip round to one off ya mates and plug your phone into their PC/laptop because it sounds like the drivers are rather corrupt or missing...
    01-11-2014 03:15 PM
  6. browsell85's Avatar
    I tried to install a new rom onto my phone and put it into recovery mode to install the new rom. after it installed, the phone restarted and just kept restarting until i put the phone in to bootloader but no recovery or rom. Just bootloader. And when i fastboot usb it doesn't show up on my pc as a htc one, just android 1.0 android device. I'm afraid i'm not gonna find a fix...
    01-11-2014 03:47 PM
  7. aspot72's Avatar
    Get latest RUU and flash it. On xda dev Mike1986 has stock ROMs.
    Sent from my XT1032 using Tapatalk
    01-12-2014 06:45 AM
  8. renz818's Avatar
    hi..have u fix your htc one olredi?
    03-19-2014 12:18 PM
  9. browsell85's Avatar
    No I haven't fixed it yet.. tried jut about everything. If I could just get in recovery or at let show up on my pc it'd be fine. I'd be able to flash anew rom and recovery.
    04-21-2014 04:27 PM
  1. [RECOVERY] Clockworkmod for EVGA Tegra Note 7
    By mattlgroff in forum NVIDIA
    Last Post: 03-13-2014, 12:58 AM
  2. I need more control
    By xchange in forum General News & Discussion
    Last Post: 01-25-2014, 03:19 PM
  3. mt wont turn on,not the usual battery issue
    By a fraking toaster in forum Motorola Triumph on Virgin Mobile
    Last Post: 01-13-2014, 03:16 PM
  4. HTC Evo Design 4g caught in Boot-Loop Help!!
    By doomjuice20 in forum HTC EVO Design 4G
    Last Post: 01-11-2014, 12:42 AM
  5. At&t samsung galaxy s4 i337 not booting into os
    By David Gilman1 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-10-2014, 06:39 PM
