Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By legaleagle07
    legaleagle07's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Any Way to Remotely Enable GPS?
    I have a Galaxy Nexus (purchased directly from Google) running Jelly Bean. Is there anyway to remotely enable GPS without rooting?
    Ahmed Harhash likes this.
  2. #2
    Dviper27's Avatar
    Posts
    Global Posts
    18 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Any Way to Remotely Enable GPS?
    Not sure what you are asking...
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry if I wasn't clear. What I would like to know is if there are any apps (or other methods) that allow me to activate my Galaxy Nexus' GPS from another device (my pc, another phone, etc.).
    If I lose my phone and GPS wasn't activated at that time, I am looking for a way that I could activate the GPS remotely to allow the phone to be located accurately with ADM or Lookout.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Nobody has an answer?
  5. #5
    someguy01234's Avatar
    Posts
    Global Posts
    1,820 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That's kind of hard because with newer version of Android, Google disable the ability to enable GPS without user interaction. Some phone can do it using Tasker with it's plugin Secure Settings with it's Helper's plugin (plugin within plugin). With KitKat, however, I found even that doesn't work anymore.
    I think phone finder apps with "device administrator" privilege may be able to do it, like Android Device Manager and Cerberus.
    You can probably create a Tasker profile that when it receive a specific SMS it will perform a task, enable GPS.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Android Device Manager does not remotely turn on GPS. If my location settings are turned off and I tried to use device manager to find my phone, it just tells me my phone can't be found.
  7. #7
    garublador's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Strangely, the remote part is easy. It's the turning GPS on automatically that's difficult. I believe in JB you have to be rooted to toggle GPS and location services requires user interaction to turn on if you aren't rooted, too.
  8. #8
    nataliardzm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is there a way now ? My phone got stolen and they turned off location before I could lock it using android device manager. And there has been no Location History on google Maps recorded since it was stolen.
  9. #9
    Rizan Zaky's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    As you're using a Galaxy Nexus, which is I believe a Samsung phone, you can get the GPS remotely on using Samsung Phone Finder, from a web browser
    findmymobile.samsung.com/login.do
  10. #10
    retkeilymaja's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok, the remote GPS cannot be enabled on Android 4.4 and above, but as mentioned above if you use the Samsung function to locate it the GPS will be enabled, even on phones not rooted. I think this works because the phone uses a system app. Unfortunatly I also have a Zenfone and I can't use this trick on it, and I don't want to root it, any other workaround available?
  11. #11
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Maybe a Zenfone tracking software as the one that is into Samsungs?
  12. #12
    PowerOverwhelming's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks buddy, this worked and i had my gps off.
  13. #13
    maxim_bo's Avatar
    Posts
    Global Posts
    14 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you need to write an application that when installing the access requests to the GPS client and shove him his. You can then remotely control. But it's a long way
  14. #14
    lbelsches's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    the locatemydevice option didn't remotely turn my GPS on. :/ (trying to locate a Samsung Galaxy S6)
  15. #15
    Yashasvi S's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is there a posibility for a LG Phone
    My Phone is LG g4 - H818 can we Remotely Enable GPS?
  16. #16
    Ahmed Harhash's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes my friends the way I 've done it successfully you can find your phone from this link
    https://findmymobile.samsung.com
    This allows your phone determine your location without having to run GPS system only needs to be Wi-Fi or mobile data works
  17. #17
    ItzYeho's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs up Re: Any Way to Remotely Enable GPS?
    Damn man, I don't know what would I've done without you. If you weren't to tell me that Secure Plugins can also turn on GPS I would've lost me phone more. Haha.
  1. Galaxy S4 home button not taking phone to home
    By homura in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-25-2014, 08:52 PM
  2. GALAXYS4 changes to 4g when screen locks
    Last Post: 01-12-2014, 07:23 AM
  3. Replies: 5
    Last Post: 01-11-2014, 06:38 PM
  4. Replies: 1
    Last Post: 01-11-2014, 05:57 PM
