Results 1 to 5 of 5
Like Tree4Likes
  • 1 Post By Golfdriver97
  • 1 Post By someguy01234
  • 1 Post By B. Diddy
  • 1 Post By QueenCersei
    Question DashClock Expanded On Home Screen?
    I've only had my Nexus 5 about two weeks so I'm very new to android so apologies if this is a n00b question.
    How do you get the expanded widgets (via lock screen) on the home screen?
    Home screen - http://i.imgur.com/JETxczr.png
    Lock screen - http://i.imgur.com/sTeeXRE.png
    The versions on the home screen are tiny and I can't get them to expand, I'm not sure if I'm overlooking a setting or something.
    I did a google search and turned up nothing but I keep seeing images of people having expanded dashclock looking widgets on their homescreen so it must be possible. :/
    I hid the clock hoping that'd force them underneath it and expanded but nada.
    Any help would be appreciated.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: DashClock Expanded On Home Screen?
    Quote Originally Posted by QueenCersei View Post
    I don't think you can expand the homescreen widget, but the lock screen one, yes. Grab the time and pull it down. You will see the settings icon next to it. Click it and you can go into settings of Dashclock and add more extensions, and change the current one's settings.
    QueenCersei likes this.
  3. #3
    You just tap and hold on the widget, it should let you resize it.
  4. #4
    I believe someguy01234 is correct--press and hold the homescreen widget until you feel it vibrate. You should then see some borders appear around the widget. You can then drag those borders to expand the widget.
    Quote Originally Posted by someguy01234 View Post
    I feel like an ***** now.
    Thank you very much though! Dumbfoundingly simple xD
    B. Diddy likes this.
  1. Galaxy S2 i9100 wont turn on!!
    By williams rios in forum General News & Discussion
    Last Post: 01-12-2014, 10:16 AM
  2. Emoji on Twitter?
    By SIMMMONS in forum Android 4.4 KitKat
    Last Post: 01-11-2014, 08:40 PM
  3. Replies: 1
    Last Post: 01-11-2014, 07:56 PM
  4. Poor signal an reception on Spring
    By Matt Bryan in forum Samsung Galaxy Note 2
    Last Post: 01-11-2014, 06:16 PM
  5. Black nexus 7 screen
    By Chris2016 in forum Google Nexus 7 Tablet (2012)
    Last Post: 01-11-2014, 05:32 PM
