1. James Seedorf's Avatar
    Oops, title mistake, should say Is in a reboot loop
    I have re-flashed the phone with a stock version (I never did any flashing/rooting before this, but have on a previous phone so I know how). I would just factory reset, but I NEED the videos I recorded today. Is there a way to pull files without booting (I can get recovery and download modes, no option is available for mounting the USB connection like I have read about). It is not in developer mode, and I don't think it would matter if it was because I can't boot past app loading (to my belief). When I flashed the device, it loaded and started "upgrading android" upon completion is said starting apps and then rebooted. If I can't pull files can I remove 3rd party apps.
    01-11-2014 08:47 PM
  2. Golfdriver97's Avatar
    Pulling files in ADB would require USB debugging in developer options checked.
    Have you tried pulling the battery for several minutes and rebooted into recovery?
    01-11-2014 10:46 PM
  3. James Seedorf's Avatar
    Yea, I have, I have now flashed CWM recovery to the device because I believe it turns on dev mode automatically, but I have gotten no further than now having a slightly different recovery mode screen, my next step is probably to load a recovery via micro sd, but I'm not sure that's my best option.
    01-11-2014 11:26 PM
  4. Golfdriver97's Avatar
    You can try to clear the device's cache in recovery. See if that will help.
    01-12-2014 12:30 AM
  5. James Seedorf's Avatar
    I cleared both caches. Sadly, it didn't do any good.
    01-12-2014 12:42 AM
  6. Golfdriver97's Avatar
    Aside from a reset, I don't know what else to suggest.
    From a Sprint Moto X using AC Forums app
    01-12-2014 09:19 AM
  1. Replies: 10
    Last Post: 09-05-2016, 12:48 AM
  2. S3 backup laden
    By ITeyo in forum Introductions
    Last Post: 01-19-2014, 07:51 AM
  3. noobiee here , need your lights for N4 !!!
    By gamermisfitz1 in forum Google Nexus 4
    Last Post: 01-12-2014, 05:54 AM
  4. Weird clocks on locked screen? Need help removing them
    By sarapoep in forum Verizon LG G2
    Last Post: 01-11-2014, 09:53 PM
  5. Replies: 1
    Last Post: 01-11-2014, 06:56 PM
