xperia ray problem
Jan 12, 2014
3
Hello.I Have been Trying to install a ROM on my Xperia Ray by Recovery after this happened I made a mis-installation (status 7) so I made reboot, the phone stuck on Sony logo and do not complete operating
What should I do??
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
What should I do??
Go back into recovery and restore a backup. If you have no backup then factory reset and try a reboot.
Lastly, you likely need to install an updated Recovery (CWM or TWRP) and try to flash the ROM again. Let us know how it works out.
bluegarland692
