1. Saladeen Al Suleiman's Avatar
    Hello.I Have been Trying to install a ROM on my Xperia Ray by Recovery after this happened I made a mis-installation (status 7) so I made reboot, the phone stuck on Sony logo and do not complete operating
    What should I do??
    01-12-2014 09:22 AM
  2. srkmagnus's Avatar
    What should I do??
    Go back into recovery and restore a backup. If you have no backup then factory reset and try a reboot.
    Lastly, you likely need to install an updated Recovery (CWM or TWRP) and try to flash the ROM again. Let us know how it works out.
    01-12-2014 10:19 AM
  3. Saladeen Al Suleiman's Avatar
    I cant Access to recovery,
    it is only stuck in the logo
    01-12-2014 10:35 AM
  4. Saladeen Al Suleiman's Avatar
    is there any way to install new Rom by Computer??
    01-12-2014 11:01 AM
  1. Downgrading to 4.1.1 Oden3 Problems
    By BryGuy86 in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 05-21-2014, 12:28 PM
  2. sound problem
    By Kevork Jaloian in forum Samsung Galaxy Mega 5.8
    Last Post: 04-17-2014, 08:42 AM
  3. Samsung Galaxy Tab 3 - Rooting Problems
    By Future Blade in forum Samsung Galaxy Tab 3
    Last Post: 01-11-2014, 10:01 PM
  4. Problem with smart screen
    By AndroiderG2 in forum Verizon LG G2
    Last Post: 01-11-2014, 09:32 PM
  5. Nexus 7 (2013) bootloop problem - bootloader doesn't work either
    By demonicangelz in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-11-2014, 06:14 PM
