1. Drakoblare's Avatar
    Hi, I've seen similliar threads but not with my problem. My tablet had 1mobilemarket installed instead of play store, but since I believe play store is better and I wish to have my gmail linked with my devices, I tried to install it. However, it won't work. I can download and install it just fine, but when I click on it I just get a white screen and it crashes. Any help?
    01-12-2014 09:28 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    Try going into Settings>Apps>Menu>Reset app preferences. That might help.
    01-12-2014 09:39 AM
  3. Drakoblare's Avatar
    After I go to apps I only get to choose "downloaded", "on sd card", "running", "all"
    No menu option
    01-12-2014 09:53 AM
  4. mrsmumbles's Avatar
    No menu option
    The menu is the button on the top (or bottom) of the screen that looks like 3 dots.
    Sent from my Nexus 5 using Tapatalk 2
    Golfdriver97 likes this.
    01-12-2014 09:55 AM
  5. Drakoblare's Avatar
    Thanks, but it didn't work
    Maybe it is the version I downloaded? I haven't seen an official link and there is no google play app on 1mobilemarket.
    01-12-2014 10:02 AM
  6. Golfdriver97's Avatar
    You could try an older version of Play. Other than that I am not sure.
    01-12-2014 10:08 AM
  7. STARGATE's Avatar
    Welcome to the forums!
    What kind of tablet is it?
    It might be one of those unsupported ones.
    Sent From Inside The TARDIS in a Galaxy S4 Away!
    01-12-2014 10:11 AM
  8. Drakoblare's Avatar
    Thanks anyways. An official site from which I can download Play on my tablet?
    At one point I unistalled 1moblie market thinking that was the problem. It seemed like it was unistalled but it was there. Even worse I can't download apps from it now, it is stuck on prepare download. I reset my tablet to factory whatever but it is still not working, so not only did it not fix anything, I lost my apps
    EDIT: It seems to be downloading now, it just tok a heck of a long time. Dunno what happened.
    01-12-2014 10:18 AM
  9. Drakoblare's Avatar
    novaPad 70 5104 FC
    It was a gift. It seems to be only in Greece. It is made by "Crypto".
    01-12-2014 10:19 AM
  10. Golfdriver97's Avatar
    Give it a few minutes and let us know what happens.
    01-12-2014 10:25 AM
  11. Drakoblare's Avatar
    Temple run 2 took a long time preparing to dwonload but I finally got it (saves were erased but that's normal I guess). Now all other apps seem to be stuck on "prepare to download".
    One more app got installed but took a looong time to prepare to download, other ones are still stuck.
    01-12-2014 10:34 AM
  12. Golfdriver97's Avatar
    Are they batch loading? I have problems with that. One by one works better.
    01-12-2014 11:10 AM
  13. Drakoblare's Avatar
    Just stuck on "preparing download" nothing else said.
    Well, 1 app just downloaded but it was loading since my last post...
    What's the point of having a tablet without apps? It's useless.... any fixes?
    01-12-2014 11:19 AM
  14. Golfdriver97's Avatar
    Try cancelling the download and restarting it.
    01-12-2014 11:22 AM
  15. STARGATE's Avatar
    Yup, but do it one by one. That might help.
    01-12-2014 08:53 PM
  16. Drakoblare's Avatar
    All is well now, it fixed itself. No playstore but whatever
    01-13-2014 08:24 AM
  17. STARGATE's Avatar
    Is there a way you could get the Amazon app store or side load it?
    01-14-2014 07:39 AM
  1. 2 way sync google contacts with Moto G is not working
    By User899 in forum Moto G (2013)
    Last Post: 04-09-2015, 03:34 PM
  2. S4 Email won't download
    By crazycrew in forum Samsung Galaxy S4
    Last Post: 01-16-2014, 11:08 AM
  3. Car Bluetooth Paired Display On In Call
    By mpeg3s in forum HTC EVO 4G LTE Rooting, Rom's, and Hacks
    Last Post: 01-12-2014, 02:46 PM
  4. Chromecast won't connect
    By Steve Gill1 in forum Google Chromecast
    Last Post: 01-12-2014, 09:53 AM
  5. The Microphone / Audio Recording on HTC One Series
    By nirajvashi in forum HTC One Series
    Last Post: 01-12-2014, 05:53 AM
