1. clc34's Avatar
    Hi
    Firstly thanks for taking the time to read this post.
    I have a water damaged phone and desperately hope I can retrieve some data - texts from my Dad who sadly died a few months ago.
    The phone was dropped in water for 20 seconds. I immediately took battery, sd and sim card out. One hour later I placed it into a sealable bag of rice and left it there for 2 days. The phone had a cracked screen prior to being dropped in water but functioned fine. Unfortunately I think I turned phone on too soon and should have left it longer in rice. When I powered phone it switched on and for about 30 seconds the screen appeared to work, the screen then went blank. The phone turns on ok and I can hear it receiving calls and texts but as screen is blank I can not take calls or actively use phone. It has now been 4 days since water damage and situation has not changed. Previously I have never used HTC sync manager before but in attempt to retrieve data I downloaded it. Once the phone is connected to computer, sync manager is not recognising that phone is connected. However, if I go in to computers control panel the phone is recognised.
    Does anyone have any words of wisdom? Are texts saved on SD card automatically? Should I take it to a repair centre? If so can anyone recommend somewhere near Manchester, uk.
    Thanks
    01-12-2014 02:18 PM
  2. ramonm2's Avatar
    I believe on a desire they save automatically to the SD card. I would try an sd card adapter and try placing it in a pc.
    01-12-2014 10:03 PM
  3. srkmagnus's Avatar
    Text messages are generally saved on the same partition as they App you are using. In this case, it's likely the /system of the internal SD card. There's no way to recover those text, that I know of, from water damaged device. You can try a repair center, but that's probably not going to work.
    01-13-2014 07:55 AM
  1. Replies: 5
    Last Post: 01-17-2014, 09:00 PM
  2. New HTC One user in need of emoji's
    By cristianocr7 in forum HTC One M7
    Last Post: 01-14-2014, 12:08 PM
  3. Note 2: Having some seriously bizarre issues with data!
    By Nibs in forum Verizon Galaxy Note 2
    Last Post: 01-13-2014, 10:40 PM
  4. Galaxy S4: Restore ROM from external SD card
    By djraysr in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 01-12-2014, 01:25 PM
  5. Replies: 0
    Last Post: 01-12-2014, 12:03 PM
