1. Hirazi Blue's Avatar
    Yesterday my one-month old Google Nexus 7 2013 froze completely, not responding to any touch and not even allowing me to power down by pressing the off-key. Eventually plugging it into my computer helped me regain control, but now I really would want to know, what could have caused this, how it could be prevented and what would be the best procedure if it were to happen again?
    01-12-2014 06:32 PM
  2. B. Diddy's Avatar
    Whenever an Android device freezes, it will usually power off if you press and hold the Power button for about 10 seconds. There are quite a few possible reasons for a device to freeze up--it usually has to do with some app that is malfunctioning on its own or conflicting with some other app. You could always try uninstalling recently installed apps to see if that helps, or uninstalling the app that was running when things froze.
    mrsmumbles and Hirazi Blue like this.
    01-13-2014 03:06 AM
  3. Hirazi Blue's Avatar
    Thanks/ So there are no hidden tricks to power down the Nexus? I ask, because I did already try keeping its power button pressed for more than 10 seconds and that didn't seem to work at the time. Will indeed have to take a look at the installed apps.
    01-13-2014 04:09 AM
  4. srkmagnus's Avatar
    No hidden tricks, just hold the power button down until it powers off and it's good. If there is anything you recently installed when the issue started the take a look at that app. Let us know how it goes.
    01-13-2014 07:42 AM
  5. Hirazi Blue's Avatar
    Only because I owned an unruly eBook reader that would occasionally freeze up completely and weirdly enough would unfreeze when connected to my PC, I had the idea to use this little unexplained trick on my Nexus as well, otherwise I'd probably still be stuck with a frozen Nexus. That's why I asked for another workaround as going to my PC for each and every freeze seems a bit tedious (especially when already in bed!).
    01-13-2014 07:59 AM
  1. S Planner Complete Tasks - Galaxy Note 10.1
    By Ross Olney in forum Samsung Galaxy Note 10.1
    Last Post: 08-23-2014, 08:53 AM
  2. Turn lock screen completly off (4.3) - possible?
    By sspoulsen in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 04-16-2014, 08:17 AM
  3. completely out of internal memory HELP
    By mandroiddrone in forum LG Optimus L
    Last Post: 02-20-2014, 12:34 AM
  4. How Do I Delete Movie Torrents Completely
    By Tico2415 in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-06-2014, 07:58 PM
  5. Replies: 0
    Last Post: 01-05-2014, 11:39 AM
