1. DanaS813's Avatar
    I have a Droid Razr and I've been having this problem for the past couple days, but I can't save pictures or screenshots. I take a screenshot and then it will appear in my gallery. After a couple minutes I will go back and the screenshot will be totally black and I can't look at it. It does the same thing with taking a picture from my camera. I've shut it down and everything but nothing helps. What should I do?
    01-14-2014 08:29 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are they saving to the internal storage or to the external SD card? If the latter, maybe the card is bad. Although I don't think there's any way to set the screenshots to save anywhere but internal storage, so I'm guessing they're all saving to internal storage.
    Try wiping the cache partition. You won't lose any personal data or settings, but it might clear out some bad bit of system data that is screwing things up. Wipe Cache Partition - DROID RAZR / RAZR MAXX by MOTOROLA
    01-14-2014 11:40 PM
  1. Camera Pictures deleted after Installing Kitkat
    By Morfie in forum Motorola Droid MAXX
    Last Post: 09-14-2014, 10:45 PM
  2. Lost WiFi on my LG ls-790 after rooting. Please help.
    By Nick Bolduc in forum Optimus Elite Rooting, ROMs, and Hacks
    Last Post: 02-05-2014, 10:21 PM
  3. Replies: 29
    Last Post: 01-26-2014, 05:00 PM
  4. Replies: 1
    Last Post: 01-14-2014, 12:33 PM
  5. navigation app missing? help please
    By sjsmith1708 in forum Samsung Galaxy S4
    Last Post: 01-14-2014, 12:17 PM
