Results 1 to 3 of 3
    Default How to sort my menu
    I have tons of apps installed & my menu lists them alphabetically.
    For easy access I had made folders on desktop to sort them.
    Is there a way I can make folders on the menu screen itself, for eg:- listings apps under GAMES, VIDEO, EMAIL & IM, etc...
    I also understand there are things called lauchers for customizations, if that is the only option to solve my problem, then which launcher should I install?
    Thanks in advance for all replies & support.
  2. #2
    Default Re: How to sort my menu
    Welcome to Android Central! With basic "vanilla" Android (like what you get in Nexus devices), you can't organize the apps in the App Drawer--that functionality is more for the homescreens. You are correct, there are 3rd party launchers where you can do this, although what you're asking for typically requires the paid version of the app. Nova Launcher Prime is the one I'm familiar with--it's quite good.
  3. #3
    hunterk11's Avatar
    Posts
    Global Posts
    15 Global Posts
    Quote Originally Posted by genesispig View Post
    I vote for adw launcher every time, simply the best with the lightest footprint
    Sent from my Venue 8 3830 using Tapatalk
  1. Replies: 41
    Last Post: 03-10-2015, 05:08 AM
  2. Will Chromecast allow me to use a 2012 Nexus 7 model with it?
    By Gregory Frazier in forum Google Chromecast
    Last Post: 01-17-2014, 09:41 PM
  3. Should I update to KitKat?
    By Scratchyjam in forum Moto G (2013)
    Last Post: 01-17-2014, 08:52 AM
  4. Use a mobile device to act as a monitor for my Galaxy Note 2
    By ryan1234567 in forum General Help and How To
    Last Post: 01-16-2014, 11:12 AM
  5. why my galaxy s3 won't update?
    By yu na in forum Samsung Galaxy S3
    Last Post: 01-14-2014, 11:52 PM
