1. jonathan vacantii's Avatar
    So, I have a sprint galaxy s4 (SPH-L720)
    BUILD # JSS15J.L720VPUEMK2 ANDROID:4.3
    I went through odin v.3 the (COM) spot was lite blue not yellow idk if that matters but it passed and installed cwm custom recovery just like it should, I then installed superuser.zip onto my .sd card and went into custom recover and installed superuser file. the only thing wrong I sawe there is that it failed to verify the signatures? but other than that it said successful/pass all that good stuff and when I turned my phone on and checked the root status it says no root access and superuser not found!!!
    Now this is not the first time ive rooted a phone, im no expert by any means but I have successfully rooted and flashed roms to many gs4's with the same computer/odin version/root files... anybody have any tips or ideas advice anything would help really... I need to get free hotspot going for a trip im going on in my rv and want to bring my xbox along to play online. also I do apologize if I posted in the wrong spot or did something else wrong im completely new to forums besides reading them..
    thanks!!!
    01-16-2014 03:31 PM
  2. UJ95x's Avatar
    thanks!!!
    As far as I know, there is no way to install a custom recovery successfully on 4.3 yet
    You also can't downgrade from 4.3, so you might be out of luck for now
    01-16-2014 09:36 PM
  3. Rukbat's Avatar
    Second, there are many free hotspot (or tethering - same thing) apps in the Play store that don't require root.
    Third, some carriers don't allow tethering and there's nothing, rooted or not, that you can do to get around that. Try a non-root tethering app. If that works, you're in business. If it doesn't, nothing will. (At least not in that direction - computers connected to the internet through your phone.)
    01-17-2014 09:11 PM
  1. samsung s3 google maps no network connection
    By bigdaddy10 in forum Samsung Galaxy S3
    Last Post: 04-14-2014, 06:17 AM
  2. New Update and Rooting
    By Firefighter4ISU in forum General News & Discussion
    Last Post: 01-16-2014, 10:28 PM
  3. Galaxy front camera snap chat v. stock camera
    By Leslie_Jeanneth in forum Samsung Galaxy S4
    Last Post: 01-16-2014, 10:23 PM
  4. Galaxy S4 to Google Edition
    By sparker781 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 01-16-2014, 09:47 PM
  5. sprint easy up
    By hardrocker89 in forum Sprint Samsung Galaxy S4
    Last Post: 01-16-2014, 02:13 PM
