1. kvsolga's Avatar
    I need some big help.....
    I decided to root my phone... worked like a charm had my phone rooted... then I decided to go and try to get Android kitkat 4.4 on my HTC One S... found out it wasn't possible so I found out someone's mod for it... decided to go along and install it but didn't follow the tutorial correctly.. then got cautious and decided to factory reset my phone but ended up removing the os.
    Now The phone turns on displays the HTC logo and turns back off... I can access recovery but that does nothing as there is no OS on the phone.
    The phone is with Talkmobile and I need to use it for tomorrow so if someone could help it would be great.
    I not the best so I guess you could call me a noob with what I was trying to do here, everyone makes mistakes!
    01-16-2014 04:21 PM
  2. VDub2174's Avatar
    Welcome to AC!!
    Did you do a backup before flashing the ROM?
    01-16-2014 04:31 PM
  3. kvsolga's Avatar
    No I didnt, feel stupid but need help
    01-16-2014 04:33 PM
  4. VDub2174's Avatar
    Let me see if I can find anything for you.
    01-16-2014 04:43 PM
  5. kvsolga's Avatar
    Thanks that would be great!
    01-16-2014 04:52 PM
  6. kvsolga's Avatar
    I went and I downloaded
    CyanogenMod Downloads
    when I flashed it on to my device and I reboot, it brings the "HTC, quietly brilliant" screen up with a white background for couple seconds and then turns off. Then it repeats the same process over and over again.
    I really need help fixing this^
    01-16-2014 06:52 PM
  7. VDub2174's Avatar
    The ROM needs to be compatible with your phone in order to work. I haven't found anything
    01-16-2014 06:54 PM
  8. kvsolga's Avatar
    The link I sent is for HTC One S and that is my phone... doesn't that mean its compatible?
    01-16-2014 06:57 PM
  9. Rukbat's Avatar
    Names mean nothing - it has to be compatible with your model number.
    Check on XDA, in the forum for your phone, and see if anyone has anything. Even if it's a lile unfinished - no GPS or no FM radio or something - you'll have a working phone temporarily.)
    01-17-2014 09:16 PM
  1. Optimus Elite problem with multi-AP WiFi w/ WPA
    By Andrew Tester in forum LG Optimus Elite
    Last Post: 01-26-2014, 08:23 PM
  2. Sprint Galaxy S4 no root access help?
    By jonathan vacantii in forum General Help and How To
    Last Post: 01-17-2014, 09:11 PM
  3. Strange Mail Problem
    By Solrighal in forum Samsung Galaxy Note 3
    Last Post: 01-17-2014, 02:15 PM
  4. New Update and Rooting
    By Firefighter4ISU in forum General News & Discussion
    Last Post: 01-16-2014, 10:28 PM
  5. Can't set custom Ringtone after 4.3 update
    By kilolima2 in forum Verizon Galaxy Note 2
    Last Post: 01-16-2014, 02:23 PM
