1. Pete777's Avatar
    Hi all,
    I'm one of those odd people who actually likes getting the haptic feedback on my HTC One-X when using it. I've had the phone a little over a year and the power saver feature was always running and I always got the vibrations.
    For some reason, now the only way to get the vibrations when generally navigating the phone is if the power saver is turned off. Note, the keyboard and all apps that utilize vibrations still do it, but the general navigation of the phone does not (unless power saver is off). I would like to keep running power saver and have the vibrations. I'm running Android v. 4.1.1
    Has anyone experienced this and if so how could it be corrected? Was there some kind of update that I didn't know about? Also, is v. 4.1.1 also known as Jelly Bean?
    Thanks!
    Pete
    01-16-2014 05:13 PM
  2. wizzrah's Avatar
    Hi all,
    Thanks!
    Pete
    When you uncheck power saver mode and then tap it (not the check box), you can choose if you want to keep the vibrations. Yes, 4.1.1 is Jelly Bean.
    Pete777 likes this.
    01-16-2014 06:15 PM
  3. Pete777's Avatar
    OK, I found that function. That did the trick. Thanks!
    01-17-2014 07:59 AM
  1. Replies: 10
    Last Post: 08-08-2016, 09:11 PM
  2. Nexus 7 vs Samsung Note 8
    By AldousSnow in forum Samsung Galaxy Note 8.0
    Last Post: 01-21-2014, 10:01 PM
  3. Swiftkey on Nexus 7 vs 5?
    By pbc in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-17-2014, 05:09 AM
  4. Tab keeps trying to power on while charging
    By Irishlt in forum Samsung Galaxy Tab 2
    Last Post: 01-15-2014, 07:34 PM
  5. Loose Power Button
    By Matt-Helm in forum Motorola Droid MAXX
    Last Post: 01-15-2014, 08:39 AM
