Results 1 to 6 of 6
    Default Samsung G S3 screen is blackout but works... need help Pleasee
    So I woke up this morning and my phone screen will not turn on. I know the phone works because the LED light will come on showing a text message and I can plug my phone into my computer and transfer music/photos. I was wondering if there was any way I could fix this? Or at the very least, use my computer to look at my text messages which are kind of important.
    I have already tried taking out the battery with no success.
    Any help would be greatly appreciated!
  2. #2
    Default Re: Samsung G S3 screen is blackout but works... need help Pleasee
    Welcome to Android Central! Sounds like a screen failure. Probably best to take it to a cellphone repair store and get an estimate, unless you have insurance or the phone is still under warranty.
    Is there any way I can get to the messages that I haven't seen? Maybe by downloading an app on my computer with Google Play?
  4. #4
    What wireless company do you use? I think some of them allow you to view messages on their webpage if you log in with your account. I know that with Verizon, you can send text messages from an interface on their webpage, but I can't remember if you can read any incoming messages.
    I'm with US Cellular
  6. #6
    Rukbat's Avatar
    Posts
    Global Posts
    22,798 Global Posts
    Carrier
    Modified Stock 4.4.2
    You can pull your texts off if you've already set the phone up for that. You might try going to the Play store on your computer and installing MyPhoneExplorer. Then install the PC side on your computer. If they link up you can pull off files, contacts. texts, etc. You can even run a remote screen to the phone and run apps, etc.
  1. Right to Work and Unions
    By NoYankees44 in forum Politics
    Last Post: 12-12-2014, 09:04 AM
  2. Need to replace sugar sync.
    By hanly2 in forum General Help and How To
    Last Post: 02-08-2014, 02:47 PM
  3. S3 running terrible! Please recommend fixes
    By blaze45 in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-17-2014, 06:03 PM
  4. Help with what could be basics :)
    By karcoo in forum Samsung Galaxy Ace
    Last Post: 01-17-2014, 05:54 PM
