Results 1 to 3 of 3
    llmike23ll's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Any possible way to extend IR Blaster functionality? 1st post please help
    I have a T-mobile LG G2 and this phone comes with an Infrared (IR) Blaster. The main advertised use is to change the channel on the TV, DVR, Blu-Ray player, etc. but i know LG also allows you to control air conditioners. Well I was wondering if it is possible to program the IR blaster to control devices other than the select few options shown on the stock app. My ceiling fan/light is able to be controlled remotely and i was wondering if there is a way to use my phone to control it instead of the included remote, as i tend to lose it. Seems like this should be within the realm of possibility as LG brags that you can program the IR blaster.
    Any recommendations would great thanks!
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,840 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    Default Re: Any possible way to extend IR Blaster functionality? 1st post please help
    1) Most ceiling fan remotes work by RF (radio) not by IR.
    2) You can probably program the IR app - if you know what the device needs for each code - or if LG provides you with a "learning" app. (You point the remote at the phone and press a button on the remote. The phone saves that code and lets you name it.) Since there's probably no IR receiver in the phone, that's probably not doable.
    I think what they mean by "programmable" is that we (the users) can write apps that program the IR Blaster.
    llmike23ll likes this.
    llmike23ll's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    After a little research i think you were right, my ceiling fan does use radio waves and not infrared. Oh well it was worth a shot.
  1. Day 5 on HTC One, may go back to Windows
    By cristianocr7 in forum HTC One M7
    Last Post: 01-26-2014, 11:33 AM
  2. Any way to display a calendar on gear?
    By recDNA in forum Samsung Galaxy Gear
    Last Post: 01-17-2014, 11:32 PM
  3. How to transfer pics via USB
    By jamak in forum General Help and How To
    Last Post: 01-17-2014, 09:06 PM
  4. Samsung G S3 screen is blackout but works... need help Pleasee
    By dgrichte in forum General Help and How To
    Last Post: 01-17-2014, 08:40 PM
  5. T-Mobile HTC One - Calls dropping back to the home screen
    By Jstonemo in forum T-Mobile HTC One
    Last Post: 01-17-2014, 06:32 PM
