1. Justin Young2's Avatar
    I have an LG g2 through Verizon.I'm using AT&T currently on this phone. Its already accepted my sim card and I'm able to call and text and I put in an APNthat I'm not really sure is correct but is giving me data. I live out in country and I used to get to bars on my HTC One but this phone gets maybe one bar sometimes and then it gets nothing. What do I need to do in order to get better service? Will unlocking it help, or putting in a different APN?
    01-19-2014 02:52 PM
  2. Paul627g's Avatar
    It may help give you more options to have the phone unlocked from Verizon. However using it out of country, especially a device designed for the Verizon " CDMA carrier " based network puts your back against the wall from the start. You also maybe limited to the specific radio frequencies the device is chipped to except. That could be the reasoning behind your poor reception. The HTC One you mentioned, could have been programmed/chipped with different radio frequencies giving you more/better options in terms of reception/service out of country.
    01-19-2014 03:42 PM
  3. Justin Young2's Avatar
    So you think ill have a small chace of getting better service? I mean, i live in the states, Kentucky to be more exact, (so thats my rural area go figure lol) an with the HTC that was ATT branded, got slightly better signal. I mean all im needing is to just not lose service. So should i just go through with it?
    01-19-2014 03:49 PM
  4. Rukbat's Avatar
    Since the phone is a Verizon phone and it's using an AT&T SIM, it's already unlocked. (Locking refers to not being able to use a SIM from another carrier). If you're staying with the carrier the phone's currently on, unlocking wouldn't accomplish anything.
    The only way unlocking a phone will give you better service is if you unlock it so you can use a different carrier - one that gives you a better signal.
    01-19-2014 10:30 PM
  1. Will I get back my old kernel?
    By junksecret in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 01-22-2014, 02:53 AM
  2. How can I stop my data from being used on Galaxy S4?
    By xonq in forum Samsung Galaxy S4
    Last Post: 01-19-2014, 11:43 PM
  3. Lg G3 Rumours.
    By Anon8154066 in forum General News & Discussion
    Last Post: 01-19-2014, 06:23 PM
  4. Replies: 5
    Last Post: 01-19-2014, 03:49 PM
  5. I need help i just deleted everything on my htc one
    By Andi Felder in forum General Help and How To
    Last Post: 01-19-2014, 12:59 PM
