1. CristinaGouveia's Avatar
    someone is having problems with the S planner? mine lost almost all functions after a software update made by samsung. Just went from the best application to something that should not be named aplication.
    01-20-2014 06:19 AM
  2. Kelly Burby's Avatar
    this is the problem with Samsung touchwiz some times it tend to losse all the functions !!
    01-20-2014 07:10 AM
  3. companionlink's Avatar
    This is one of the biggest concerns with stock apps - your experience is at the mercy of the device manufacturer's QA and software team. With each manufacturer often required to make multiple versions of their phones for each carrier, the permutations of devices can be mind boggling. Not to bail them out, but the QA teams are usually burning midnight oil. That's never good for us owners of devices.
    This is where 3rd party apps really shine because they can afford to focus on a single function of the phone (ie - calendaring). More importantly, OS updates don't affect these apps as notoriously as stock apps. There are many independent calendar apps that may outshine the S Planner. If integration with your Google account is a concern, many apps support that as well.
    01-29-2014 02:43 PM
  1. S-Planner - remove Facebook birthdays but keep events
    By Adam Jantunen in forum AT&T Galaxy S III
    Last Post: 04-24-2015, 03:07 PM
  2. S Planner Complete Tasks - Galaxy Note 10.1
    By Ross Olney in forum Samsung Galaxy Note 10.1
    Last Post: 08-23-2014, 09:53 AM
  3. S planner
    By CristinaGouveia in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-20-2014, 07:13 AM
  4. [APP][FREE][4.0+] Call Planner
    By Martin Jelinek in forum Android Apps
    Last Post: 01-12-2014, 12:10 AM
  5. S planner widget disappered in nova launcher.. any fix for this?
    By ozgurs in forum Samsung Galaxy Note 3
    Last Post: 01-07-2014, 03:18 AM
