1. hg1027's Avatar
    Hi all
    I have enjoyed my nexus 7 2103, on 4.4.2, for a few weeks now. I got adblockplus to clean up my browsing. My office wifi wasn't letting me ssh tunnel to my home server, so I set up hotspot vpn shield, but it limits usage in the free version. So I grabbed connectbot and proxydroid to get in, root using wugfresh to make those work properly. Got what I needed from the home server, shut it down, and headed for home.
    So I got home, and Chrome now says Unable to connect to proxy server. So I made sure connectbot and proxyserver were not connected, and deleted the profiles I'd set up. No luck. Deleted the apps. No luck. Deleted the apps, no luck. Turned off ad block plus and deleted that, no luck. Cleared out hotspot vpn shield, deleted, nothing.
    So I tried factory reset, no luck. Then I read that some people have had luck reinstalling those apps that changed proxy settings, which hasn't worked for me yet. I've tried restoring the backup I made preroot, no luck.
    What can I do to get my nexus back online?
    *** So as soon as I posted this, I finally found the proxy settings under kitkat (totally different than older versions, you press and hold the network name, NOT intuitive). I'm back online, and will tell my self I'll be more careful in the future. But I won't be.
    Mods, delete as I'm an *****, or leave up as a warning to future idiots.
    01-21-2014 03:26 PM
  2. Rukbat's Avatar
    Same thing in 4.3. Long-press the network name, Modify network config, Show advanced options, Proxy settings.
    01-21-2014 11:09 PM
  1. Stream video to PS3
    By ryanm33 in forum General Help and How To
    Last Post: 03-05-2015, 11:23 AM
  2. How can I make sure contacts are synced to my Google account?
    By House seller in forum AT&T Samsung Galaxy S4
    Last Post: 10-17-2014, 05:40 PM
  3. only allowed to paste?
    By Mimi A in forum ASUS MeMO Pad HD7
    Last Post: 01-21-2014, 11:40 PM
  4. Replies: 2
    Last Post: 01-21-2014, 04:17 PM
  5. Can't enable Wi-Fi!!!
    By manouila in forum Samsung Galaxy S4
    Last Post: 01-21-2014, 02:40 PM
