Results 1 to 3 of 3
    Default Zooper Widget not refreshing
    I have Samsung Galaxy S4 and have made some cool widgets with Zooper Widget. These worked fine initially but some of the widgets with time features get stuck on the time or incorrect city and don't display the correct city or time. Any thoughts on how to fix this?
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Zooper Widget not refreshing
    Are the widgets setup to refresh from time to time or when location has changed? See if there are settings for such. Also check to make sure the widget supports active updates to those features based on location.
  3. #3
    theT5E's Avatar
    Posts
    Global Posts
    14 Global Posts
    I have the same problem [Nexus 5]
  1. 4.3 Screen Timeout Not working
    By ToddL in forum Verizon Galaxy Note 2
    Last Post: 11-07-2015, 09:02 AM
  2. Samsung S4 will not change lock screen
    By saraj12 in forum AT&T Samsung Galaxy S4
    Last Post: 01-30-2014, 07:05 PM
  3. Viewing Missed Calls ->Not a contact?
    By DroidGuy155 in forum Google Nexus 5
    Last Post: 01-21-2014, 09:14 PM
