Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By srkmagnus
    Default I don't get notifications on home wifi
    Lately I have realized that at home I don't get notifications from most of my apps. I have notifications turned on and I do get them pushed to me when I go to other places with high-speed internet. The internet at home isn't blazing fast but isn't slow at 13 Mbps. I don't get notifications for most games and some other apps, like hangouts, where I could end up missing out on a conversation because I never got the notification. I get notifications about new emails and updates from the Play Store but that's about it. Is there something I can try or do to fix this problem and get my notifications?
    Device: Samsung Galaxy Tab 2 10.1 running 4.2 Jelly Bean
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    6,760 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Default Re: I don't get notifications on home wifi
    Seems more like a server issue with Google or your home network not allowing you to connect. I would suggest a reboot of the router if you haven't already done so.
    B. Diddy likes this.
    I tried resetting the router but so far still no notifications. Are there any settings on the router that might be blocking notifications?
    Quote Originally Posted by srkmagnus View Post
    Anybody else had problems not getting notifications on certain wifi networks?
  5. #5
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    The only problem would be the router dropping incoming packets because the correct ports aren't forwarded to the phone. I have no ports forwarded to my phone and get all my notifications, so that's evidently not an issue with Android notifications.
  1. Don't receive notifications at home
    By kgr730 in forum Samsung Galaxy Tab 2 10.1
    Last Post: 01-27-2014, 11:32 AM
  2. Does S Note on the 2014 Sync with Google Drives?
    By she loves in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-22-2014, 09:21 AM
  3. Samsung Galaxy S3 Mini Notifications
    By Nop1980 in forum General Help and How To
    Last Post: 01-22-2014, 08:15 AM
  4. stuck on google password
    By Adalberto Diaz in forum General Help and How To
    Last Post: 01-21-2014, 10:40 PM
  5. Samsung note II has flashing blue light and wont power on
    By cupiddog321 in forum Samsung Galaxy Note 2
    Last Post: 01-21-2014, 07:21 PM
B
