1. confussled's Avatar
    I've just upgrade my S2 from andriod 2.3ish to 4.1.2. Before doing so I changed the default system sound to that droplet sound (in the normal settings view, no root, nothing special with this phone) but now I've upgraded the 'normal' setting to change 'system sound' has gone. ;(
    Have they really just scrapped that option??
    Thanks
    01-22-2014 01:13 PM
  2. srkmagnus's Avatar
    I don't have the S2 any longer, but can you not go into sounds and adjust the various Sound levels and tones? Or, are you referring to overall system sounds, like when you press a menu option within the device settings?
    01-22-2014 01:31 PM
  3. someguy01234's Avatar
    No, the System sound is a unique sound channel on Android. But in KitKat it is integrated with the Call channel so you can no longer manually set it, you can try but it will change the Call volume as well since they are one.
    You can use the app Quick Settings or Light Flow to change the System volume.
    sent via tapatalk
    srkmagnus likes this.
    01-22-2014 03:05 PM
  4. confussled's Avatar
    the sounds settings pages has a volume settings page which still has a separate volume setting for 'system' (next to media, call and notifications) but on the settings page itself only 'call' and 'notifications' are mentioned to change tones, not system. (not sure about the correct names since I've got a Dutch version)
    So I'm basically just looking for a way to change the tone of the system sound. If an app would do the trick, that's ok, as long as the tone doesn't revert after removing the app again
    01-25-2014 07:04 AM
  1. Lock buttons while in Youtube
    By SleepingBears in forum Samsung Galaxy S3
    Last Post: 02-07-2014, 05:45 AM
  2. Google Play Store error "RPC:S-3" when trying to update or install any apps.
    By ErnestCox1 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-24-2014, 12:08 PM
  3. Can someone post the end-all be-all guide to AT&T 4G LTE APN Settings?
    By arbour0713 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 01-23-2014, 08:52 AM
  4. How to use ADB To Lock Phones?
    By blakebarkertech in forum Android 4.0 Ice Cream Sandwich
    Last Post: 01-22-2014, 11:56 PM
  5. Replies: 2
    Last Post: 01-22-2014, 02:50 PM
