Results 1 to 11 of 11
    secrecyguy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Turning my phone into a WiFi Hotspot
    I have a Samsung S3 with VirginMobile. I know in the past several years ago, you have to root the phone in order to make your phone into a WiFi Hotspot.
    I just wondering if this is still true? Can I make my phone into a WiFi Hotspot without rooting the phone? If so, how can I do it?
    The reason I ask, I am planning to get an Android tablet. I am going to end up getting a off brand Android tablet.
    Thanks for any help!
  2. #2
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Turning my phone into a WiFi Hotspot
    Quote Originally Posted by secrecyguy View Post
    well, in android you can do this without rooting there is an option called as tethering that allows you to turn your device into a wifi hotspot !!
    secrecyguy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Kelly Burby View Post
    I checked but doesn't have that option.
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    There are plenty of non-root tethering apps, the problem is VM. It appears that, like Verizon, they're blocking tethering unless you pay for a tethering account. Since the blocking is done at the office, there's nothing you can do at the phone to get around it. Enjoy it while you have it - it may not last long.
    secrecyguy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Rukbat View Post
    I don't have Verizon. I have VirginMobile.
  6. #6
    Banned
    Posts
    Global Posts
    706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yes it has goto the settings> more settings>tethering and portable hotspot check it out !!! you will find it there if you are running Jellybean or KitKat OS .
  7. #7
    sk8trix's Avatar
    Posts
    Global Posts
    836 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM9
    Here dude this is short video I made for you hope it helps turn on the hotspot.
  8. Thread Author  Thread Author    #8
    secrecyguy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Nope. Not there.
    - - - Updated - - -
    Quote Originally Posted by sk8trix View Post
    thanks but I don't have that option.
  9. #9
    sk8trix's Avatar
    Posts
    Global Posts
    836 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM9
    tryo to post a screen shot of your settings man maybe its hidden elsewhere
  10. #10
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I said that it appears that, like Verizon, VM is also starting to block free tethering. Once we figure out how to get something for free, the corporations are going to figure out how they're going to charge you for it.
    When I was a kid, one of the jokes was that if they could figure a way they'd charge for air. It's no longer joke - try to fill your tires for free. I wouldn't be totally amazed if, in a few years, every time you looked at the time on your phone, it cost you something.
  11. #11
    Banned
    Posts
    Global Posts
    706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Nope. Not there.
    - - - Updated - - -
    So, can you tell us which version of Android you are using ! It may be hidden somewhere else....
  1. Replies: 9
    Last Post: 11-14-2014, 09:11 PM
  2. Replies: 2
    Last Post: 02-04-2014, 08:49 AM
  3. Help for syncing my Note 3
    By sonic1519 in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 01-31-2014, 09:20 PM
  4. I need help i deleted everything off my internal memory!!!!
    By bigsmokeldn OT in forum Samsung Galaxy S4 Google Edition
    Last Post: 01-27-2014, 08:50 PM
  5. Flashed A Nightly and My Phone Died of Heat!
    By Luis Jimenez5 in forum HTC One M7
    Last Post: 01-24-2014, 06:00 PM
