1. MFThomas's Avatar
    It's usually when I'm browsing the Chrome app. If I'm in it for more than a couple minutes, app in the background like Pandora or PVSTAR+ are killed without warning. Also, when I leave Chrome, app icons are slow to load/open, and the app menu is slow to open. I'm not sure Chrome is the reason for this but it is the most memory intensive apps on the phone
    I searched the problem and one of the solutions I read was to do a factory reset because one of the apps may have been a bad install or something. When I did this, it seemed to work at first, but the problem just came back later in the same day.
    I've had the phone since the end of 2012, but this problem has just started in the past few months
    EDIT: I actually had it replaced during the summer due to SIM card issues
    01-23-2014 06:13 PM
  2. B. Diddy's Avatar
    Have you tried turning off JavaScript? Open Chrome, tap Menu, then Settings, then Content Settings, and uncheck "Enable JavaScript."
    01-23-2014 09:09 PM
  1. Music and Ringtones
    By ttfn92 in forum Moto X (2013)
    Last Post: 01-27-2014, 07:57 PM
  2. Anyone interested in the Framily Plan on Sprint?
    By Mark Zagotti in forum Verizon
    Last Post: 01-25-2014, 09:39 PM
  3. New contacts not importing into google contacts
    By doublestack1 in forum Motorola Droid MAXX
    Last Post: 01-25-2014, 03:18 PM
  4. S4's built in "Remote Viewfinder" + Nexus 10?
    By FutureKix in forum Samsung Galaxy S4
    Last Post: 01-24-2014, 04:52 PM
