1. Stefan Vuckovic's Avatar
    Hello people, I have a problem with Viber when on wifi, can not receive calls (when phone is locked) but only get notifications for missed calls when i unlock the phone. On mobile data all works nicely. Do you have an idea how this can be solved? Messages are doing nicely on both Viber and WhatsApp.
    01-24-2014 10:14 AM
  2. Stefan Vuckovic's Avatar
    No man, i dont even now how to set it like that, all other notification are comming, just i have problem with viber callswhen its locked...
    01-24-2014 12:12 PM
  3. Stefan Vuckovic's Avatar
    I figured out the problem. Solution: set phone's wifi sleep policy to turn off the wifi when phone goes to sleep, and then in Viber's wifi sleep policy put option to always keep wifi on. That's how i solved my problem and now calls are comming just like messages.
    01-25-2014 05:20 PM
  4. Stefan Vuckovic's Avatar
    unfortunately it lasted for me 2 days and now again problem. I figured out another solution, install wifi timeout app from Google store, then set it to 0 sec, in WiFi sleep policy put option to disable WiFi when screen is locked. Also do this in Viber.
    Then ur phone will use 3G (mobile data) when its locked, and push notifications will arrive on time, and when u unlock it it will use WiFi. That's now solution that works for me good.
    01-30-2014 05:28 AM
  5. Stefan Vuckovic's Avatar
    another solution is to just install advanced wifi lock and problem is solved. it is problem with rom, it shuts down wifi when phone goes to sleep.
    02-10-2014 11:21 AM
  1. WiFi Issues in Note 3
    By EpicInYourFace in forum Samsung Galaxy Note 3
    Last Post: 10-04-2016, 08:08 PM
  2. Wifi works great, but sometimes connects to a neighbors wifi.
    By kmcdonald22 in forum Samsung Galaxy S3
    Last Post: 01-26-2014, 08:46 PM
  3. Replies: 3
    Last Post: 01-26-2014, 08:30 AM
  4. Note 3: A problem switching from Wi-Fi to mobile network
    By Crxssroad in forum Samsung Galaxy Note 3
    Last Post: 01-24-2014, 01:40 PM
  5. Volume moves down on its own to off
    By Michael Tennessee in forum Samsung Galaxy S4
    Last Post: 01-24-2014, 10:53 AM
