1. John Nield's Avatar
    Hi there, only just joined site as have had problem with this phone for a while now but left it alone untill my GF nagged me to try and fix it, but am very stuck and confused so here it goes....
    the phone's carrier was virgin mobile so i downloaded an app to unlock it to another carrier but phone froze during process so had to power off and on the it got stuck on logo screen so some how i managed to install twrp v2.6.3.0 onto the phone but i am now just stuck here the phone now has no operating system and it showing internal memory as 0mb and i can only mount external SD.
    Please if someone can help me i would be very very happy as its driving me crazy...serious.
    Hope this post is in the correct section and any other info required i can give if needed.
    Thanks in advance
    John
    01-24-2014 03:49 PM
  2. someguy01234's Avatar
    Just download a compatible rom, put it in the sdcard and flash it with using TWRP.
    I am assuming you mean Virgin Mobile in Europe and not USA, if that's the case, any roms here should work: Galaxy S III Mini Original Android Development - xda-developers
    01-24-2014 06:57 PM
  1. Replies: 21
    Last Post: 06-07-2016, 11:04 AM
  2. Verizon S3: Need to change Rom 4.3 ota screwed up my phone
    By John Williams16 in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 01-24-2014, 07:57 PM
  3. Samsung galaxy mini s2
    By Jasmine Harling in forum Samsung Galaxy S II
    Last Post: 01-24-2014, 06:22 PM
  4. Sprint HTC One > flashed wrong rom > no cell/data
    By damondroid in forum HTC One Rooting, ROMs & Hacks
    Last Post: 01-24-2014, 05:19 PM
  5. Pin Number No Longer Works
    By braveheart102 in forum HTC Desire X
    Last Post: 01-24-2014, 12:49 PM
