1. ilyabyk83's Avatar
    Hi. I have a question;
    My Samsung Galaxy S3 has a bluetooth over-the-ear handsfree adapter connected most of the time during the day PLANTRONICS Voyager Legend Black Bluetooth Headset
    Few days ago, I also bought this item GOgroove FlexSMART X2
    Both are BLUETOOTH; is my phone's bluetooth smart enough, to, when I enter the vehicle each time, to disconnect my earpiece device, and to connect it with this X2?? Or would there be needed any additional steps taken by me, each time I'll enter my vehicle? THANK YOU FOLKS!!
    01-24-2014 05:04 PM
  2. Rukbat's Avatar
    The phone will connect to the first paired device it finds, so you're going to have to manually turn the devices on and off. The phone has noway of knowing that today, for some reason, even though you're in the car, you'd prefer to have the Plantronics connected.
    There may be an app that allows you to toggle between Bluetooth devices, but I've never noticed any.
    01-24-2014 10:00 PM
  3. ilyabyk83's Avatar
    So, you think signal from my earpiece will over kill this hands free??
    So, if I want my car's Bluetooth to work, kill my ear piece??
    Sent from my SGH-T999
    01-24-2014 10:29 PM
  4. Rukbat's Avatar
    Not overkill it - the one the phone's on is the one it will stay on. If you turn the earpiece off, and there's another signal the phone is paired to, it should switch.
    01-26-2014 11:38 PM
  1. Photo gallery changed to camera roll
    By deb1262 in forum Motorola Droid Ultra
    Last Post: 09-20-2016, 07:55 PM
  2. Note 3: Haptic Feedback not working?
    By Lilshaq65 in forum Samsung Galaxy Note 3
    Last Post: 08-26-2015, 11:12 AM
  3. Mac OS 10.9 with ATF will not recognize Kindle Fire HD 2013
    By Mel2Brad in forum Amazon Kindle Fire HD
    Last Post: 05-04-2015, 06:55 PM
  4. HTC Rezound: Want to return to stock but having severe issues...
    By Phillip Declet in forum Rezound Rooting, ROMs, and Hacks
    Last Post: 01-27-2014, 04:51 PM
  5. Help with my LG Enlighten
    By JD_015 in forum LG Enlighten
    Last Post: 01-24-2014, 06:15 PM
