1. Motasem_Alwazir's Avatar
    My friend has updated his Samsung S2 to 4.0.3
    he has a problem in the keyboard
    as you see in the picture
    for example at the letter ا there is another letter which is أ .
    Before the update , when you quickly double click the letter it writes the second letter.
    After the update this feature has stopped.
    How can I fix this ?
    thanks in advance
    01-24-2014 06:34 PM
  2. joyahya's Avatar
    You can use this site Arabic keyboard hhhhh kidding with you, I think that you should re-update
    cordially
    05-24-2014 05:54 PM
  3. Nael Omar's Avatar
    Just keep touch it will show the rest
    10-31-2016 05:33 AM
  4. treetopsranch's Avatar
    Yes, try long press like Nael says.
    10-31-2016 10:18 PM
  1. Nexus 5: Reception Problem on AT&T, 2G Area
    By RealDogBoy in forum Google Nexus 5
    Last Post: 02-10-2014, 01:53 PM
  2. Droid DNA: battery or motherboard problem?
    By Zero_Lord in forum Verizon Droid DNA
    Last Post: 01-27-2014, 04:48 PM
  3. Help needed, weird problem.....
    By juliehtc1 in forum HTC One M7
    Last Post: 01-25-2014, 06:05 AM
  4. Samsung Galaxy ACE S5830L flashing problems
    By vargas7 in forum Android Graveyard
    Last Post: 01-24-2014, 04:09 PM
  5. Problems with playing videos on Facebook
    By henrodstone in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-24-2014, 02:41 PM
