create a gmail group
honex97
277
7
So I have a group of people I want to send an email to and I want to email the same group like once a week but I Dont want to manually type in there names every time. I went on my contacts app and added these people to a group and named it test just to test it out but I Dont see how to add that whole group to my email. Any help would be awesome
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
Unfortunately, there is no native way to send an email to a whole Group from your Google Contacts. I use Gmail Group Share, which works pretty well, and uses your Group information from Google Contacts. You just have to go into its settings and check "Show System Groups" and "Show Invisible Groups" to make sure all of your groups show up.
honex97
277
7
Thanks I'll try that. I can't believe there's not a native way to do that it seems like such a basic feature
DenverRalphy
Retired Network Mod
May 11, 2010
518
54
You can send email/gmail to groups from the Contacts app.
Depending on which contacts app you're using (stock/sense/touchwiz/etc..) the exact steps may differ, but IIRC they all allow for it.
For example... Using the GS4 touchwiz contacts app, I just go to Contacts -> Groups -> Longpress on the Group -> Send Email -> Select All -> Done, and then I'm sent to the email/gmail app of my choice.
*note - The "Longpress on the Group" step is a shorter method, but the same can be accomplished by tapping the group -> press menu -> send email.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
This is unfortunately not possible with the stock People app from Android. What you're describing is a modification by Samsung.
honex97
277
7
Yes I have a gs3. Yeah soon to be thunderbolt is way out of date haha I need to change that
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
Oh, well there you go--did DenverRalphy's suggestion above help, since you have a Samsung device?
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
You can also do it with the email app (the envelope with the red @). Tap the icon to the right of the To box and it takes you to Groups in the Contacts app. Pick a group, pick all or individuals, tap Done and they're all in the To box. Or you can CC or BCC them.
honex97
277
7
I downloaded that app. I prefer that because it's so easy so I'll just keep using that. Thanks
onlyoneromeo
141
Ok i tried using that app and i keep getting an error message and it wont send the email out. Does anyone know if there is a limit as to how many people you can email at one time? Im on a note 3 btw.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
Are you referring to Gmail Group Share? If so, after you select the group you want to email to, are you getting a selection window to choose which app to complete your action with? You should pick Gmail for that.
