Results 1 to 5 of 5
    Bunky67's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default SD Card File removal ?
    I had to get a new android and sprint gave me a Galaxy S2 in place of my Samsung Conquer, Well when sprint set up my new phone they just installed my SD card from the Conquer, Now when I go to my files, it shows SD card and EXT SD card, I want to remove the fines and the EXT SD card, all my files, folders, photos etc. are in the SD card folder, and work correctly,
    I have already tried to delete it through the phone, and it won't let me delete the folder, and If I put it in my laptop only the SD card shows up with only part of my folders and files,
    How can I remove the EXT SD card Folder ?
  2. #2
    Gekko's Avatar
    Banned
    Posts
    Global Posts
    8,236 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: SD Card File removal ?
    ASTRO File Manager with Cloud
    Metago - January 2, 2014
    Productivity
    https://play.google.com/store/apps/d...go.astro&hl=en
  3. #3
    B. Diddy's Avatar
    Posts
    Global Posts
    78,012 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Welcome to Android Central! First off, make sure you understand the difference between the "SD card" designations, which can be confusing. Read this guide for more info: [GUIDE] Android Storage Memory and How to Deal with Insufficient Storage Warnings
    Bunky67's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the Replies,
    At first I didn't understand the difference in the SD and EXT SD cards, but now I do
    but should I have a Android and data folders in my EXT SD folder ?
  5. #5
    B. Diddy's Avatar
    Posts
    Global Posts
    78,012 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Yes--certain apps will use the external SD card for data storage, so just leave those folders alone.
  1. How do I remove icon??
    By mystic122468 in forum Verizon Galaxy S3
    Last Post: 01-27-2014, 03:53 PM
  2. Sim card removed error
    By thekarens in forum Google Nexus 5
    Last Post: 01-26-2014, 06:20 PM
  3. How to know if i have a good file
    By abarzua21 in forum AT&T Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 01-26-2014, 05:29 PM
  4. how to download to the sd card?
    By l56force in forum Samsung Galaxy Note 10.1
    Last Post: 01-26-2014, 12:51 PM
  5. Samsung Galaxy S4 Issue Download to SD Card Unsuccessfull
    By Maynor Bustamante in forum Samsung Galaxy S4
    Last Post: 01-25-2014, 08:52 PM
