Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By minnieusa
    Default How to print from Galaxy S3
    heellp HOW to print from web or text
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,719 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: how to print from galaxy s3
    Quote Originally Posted by s2linen View Post
    Haven't really done it myself, but have you checked for an app from the manufacturer? I think HP has one in Play.
  3. #3
    You have to have a wireless printer too
    Sent from my SCH-I535 using AC Forums mobile app
    Golfdriver97 likes this.
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    I use Cloud Print. Very easy to set up and easy to use. (Share, in most apps, will let you "share" to the printer.)
    You don't need a wireless printer, as long as you're willing to leave one computer turned on. Connect the printer to that computer, set it up as a local printer and share it. Use the computer's IP address as the printer's IP address. (You can even turn the computer off, as long as you have it turned on any time you need to print from the phone.)
  1. How to print from Verizon Samung Galaxy S3 to HP 4500
    By s2linen in forum Verizon Galaxy S3
    Last Post: 02-02-2014, 09:37 AM
  2. How do I remove icon??
    By mystic122468 in forum Verizon Galaxy S3
    Last Post: 01-27-2014, 03:53 PM
  3. HTC One - Return to Stock
    By meekowave in forum HTC One M7
    Last Post: 01-26-2014, 05:26 PM
  4. Can't get music voice control to work
    By Dansole in forum Verizon Galaxy S3
    Last Post: 01-26-2014, 09:53 AM
  5. Samsung Galaxy Note 3 not using the normal sounds for locking and unlocking
    By Tommy Sebestyen in forum Samsung Galaxy Note 3 in Canada (Bell/Rogers/Telus)
    Last Post: 01-26-2014, 09:50 AM
