Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By srkmagnus
    Default I'm having issues when receiving pictures on my LG G2....
    When a friend sends me pictures from his Motorola RAZR (running 4.1.2 stock on Verizon) sometimes I'm able to get them but most of the time I get an odd looking image that isn't the picture he initially sent me (I'm running 4.2.2 on my G2 with AT&T). Can somebody please help me with this issue I love my G2 it is the best phone I have ever owned and I would like to keep it but this issue is kinda big.
    Posted on my LG G2 via Android Central App
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,751 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: I'm having issues when receiving pictures on my LG G2....
    Quote Originally Posted by Robman87 View Post
    Not sure what to suggest. Perhaps the image is in error upon sending?
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Make sure the device is updated. If still no improvement try a messaging App replacement and see if the images are received with that.
    Golfdriver97 likes this.
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Is it a distortion of the picture he sent, or is it a totally different picture? If it's totally different, I'd look to his end - Verizon is assigning the wrong links to the wrong files. (This could be a major security issue for them, so I'd think they want to get right on it.)
    If it's distorted, it could be on either end. If it's just about maximum size allowable, that could cause problems.
    Me and said person downloaded the app "textra" and compared Apn MMS settings and his Proxy port # was set to 0 (mine was set to 80) so I changed mine to 0 to match and he sent a picture to test it out and it worked I got the picture fine then he tried to send same picture via the stock messaging app and it did not work I got the same odd looking image that wasn't what he sent... Any thoughts? Or explanations?
    How do I post pictures on this forum so I can show u a screen shot of the odd looking image
  7. #7
    Posts
    Global Posts
    32,751 Global Posts
    Carrier
    When writing a post, hit the 3 dot menu at the upper right hand corner. Then click attach image.
    From a Sprint Moto X using AC Forums app
  8. #8
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Check your APN. Maybe check it against his. They also define the port numbers, and if it's an incorrect port number that's causing it, an incorrect one in the APN would cause it too.
  1. Disable "My Magazine"
    By Dale_M in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 08-24-2014, 03:39 AM
  2. Having to reboot phone to connect to WiFi
    By MamaDeLeo in forum Samsung Galaxy S4 Mini
    Last Post: 02-24-2014, 09:31 AM
  3. Replies: 4
    Last Post: 01-28-2014, 01:46 AM
  4. I'm having issues when receiving pictures on my LG G2...
    By Robman87 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-26-2014, 01:43 PM
  5. Changing personal message on lock screen
    By malamute63 in forum Samsung Galaxy S4 Mini
    Last Post: 01-26-2014, 12:31 PM
