Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By someguy01234
  • 1 Post By B. Diddy
    wazoozaw's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Cannot delete devian.tubemate.slide app which is draining 50% of my battery!
    Hi all,
    I've recently downloaded the Tubemate Slide app, an update of the Tubemate, but uninstalled it soon after as it didn't work fully (audio was not downloaded).
    However, when I checked my battery performance later today (on my Nexus 10), I saw the app is still draining 50% of my battery!!
    I don't know how it can still be on my tablet when I've uninstalled it. I've also ran a search through File Manager, but nothing came up..
    I've also turned my tablet on and off, but to no avail.
    Finally, I tried clicking on the icon/message in the battery 'window' (to get more info about the app), but the buttons 'force stop' and 'report' are greyed out for some reason.
    The app was also not listed under Settings > Apps > All apps.
    Has anyone had the same problem, or does someone know how to get rid of this app?? Thank you so much!!
  2. Thread Author  Thread Author    #2
    wazoozaw's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Cannot delete devian.tubemate.slide app which is draining 50% of my battery!
    Here are some screenshots to further clarify my situation:
    wazoozaw's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy Re: Cannot delete devian.tubemate.slide app which is draining 50% of my battery!
    I did read "[WARNING] There are so many virus applications(ad-wares) named 'TubeMate' in the market.", so I downloaded from a verified site..............but it looks like that was a fake, too. Weird, because with my first version of Tubemate I had no problems, so I figured that the link I got from them would be fine. Ok, so let's say I've been stupid, is there any way to resolve this without having to do a factory reset?
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    Your anti-malware programs didn't catch it?
    wazoozaw's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok second stupid move - I didn't have any... .__.
    Pretty stupid, I've got loads on my PC.
    Could you recommend any? And would it still catch it if it's already on there?
  6. #6
    someguy01234's Avatar
    Posts
    Global Posts
    1,820 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    PC antivirus does not detect Android virus. Just factory reset your phone and see if it will remove it.
    You can go to Settings - Security - Device Administrators and check to see if that app is there, if it is then uncheck it which can make it uninstallable.
    Plenty of antivirus on the Playstore.
    sent via tapatalk
    srkmagnus likes this.
  7. #7
    B. Diddy's Avatar
    Posts
    Global Posts
    77,850 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by wazoozaw View Post
    I like Lookout, which is generally at or near the top of many antivirus tests and rankings.
    I agree with above, it's worth checking Device Administrators, but you will probably need to do a factory reset to get rid of it completely.
  1. Replies: 37
    Last Post: 01-31-2014, 12:39 AM
  2. cm11/vanir Rom 4.2.2 destroyed my data signal, even after reverting to backup of previous Rom
    By tooandrew in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 01-30-2014, 06:24 PM
  3. Moving apps to SD card
    By Bennett Preskill in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-27-2014, 10:52 PM
  4. Excruciatingly bad battery life - please help!
    By Jake_15 in forum Samsung Galaxy S II
    Last Post: 01-27-2014, 01:55 PM
  5. Replies: 0
    Last Post: 01-27-2014, 01:54 PM
