1. monsow's Avatar
    Hey guys!
    I was wondering whether or not it is possible to auto-expand DashClock on my Nexus 5?
    Right now, I have to swipe down before I can access the information from DashClock. I would like to know if there are some settings that will auto-expand DashClock whenever I turn on my screen.
    I am not rooted by the way.
    Thanks for the help!
    01-27-2014 06:43 PM
  2. HNNNNNGHHH's Avatar
    DashClock does not have an option that lets it expand by default but most ROMs have a feature which will maximize all lockscreen widgets which will achieve the desired effect you're looking for. I'm not too sure if it's on the stock N5 ROM though.
    01-27-2014 08:26 PM
  3. monsow's Avatar
    Okay, thanks for the help. I'll see if there are other apps, as I don't want to flash a custom rom.
    01-28-2014 05:06 AM
  1. How do I disable auto-correct on the Note 3's keyboard?
    By James Heilig in forum Samsung Galaxy Note 3 in Canada (Bell/Rogers/Telus)
    Last Post: 08-20-2016, 10:08 AM
  2. Replies: 3
    Last Post: 10-22-2014, 03:34 AM
  3. Expanded Desktop Rooted Stock Kitkat Rom
    By 1210saad in forum Google Nexus 4
    Last Post: 01-26-2014, 04:38 AM
  4. Expanded Desktop On Rooted Stock KitKat Rom
    By 1210saad in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 01-24-2014, 07:23 PM
