Results 1 to 2 of 2
    Default How do I connect Galaxy Note 10.1 2014 to internet via PC
    Hi
    My note 10.1 2014 edition is rooted.
    When I use the Android Tool solution found on XDA developers, it detects my device, but always shows an error stating that ADB is unstable. How do I fix this
    If it's not possible to fix it, are there any other ways to connect my Tablet to the internet via USB? I don't have WIFI, and mobile data is expensive
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: How do I connect Galaxy Note 10.1 2014 to internet via PC
    You can download FoxFi from the Play Store and see if that will allow you to established a world tether through the PC. It should work with your device and get you connected.
  1. S3 Taking Longer to Charge
    By androidforum in forum Samsung Galaxy S3
    Last Post: 01-30-2014, 02:30 PM
  2. Ringtone and Notification sounds resetting to default...
    By Jwestphoto in forum Droid RAZR MAXX
    Last Post: 01-29-2014, 09:53 PM
  3. Replies: 6
    Last Post: 01-29-2014, 12:22 PM
  4. Connectivity problem with app store - anyone else?
    By PiggyMiddle in forum Moto G (2013)
    Last Post: 01-29-2014, 10:44 AM
  5. Copying ringtones from one phone to another?
    By MikeO89 in forum General Help and How To
    Last Post: 01-28-2014, 10:21 PM
