Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By srkmagnus
  • 1 Post By brosko
  • 1 Post By B. Diddy
    Default Best wireless (Qi) charger for Nexus 7 (2013)?
    The title says it all. I'm noticing my N7s charge port is getting a bit lose, so I figured I should I have a backup way to charge just in case. Google's is out of the question at $50 (!!!!)
    Sent from my Nexus 7 using Tapatalk
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,694 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Best wireless (Qi) charger for Nexus 7 (2013)?
    I bought Zens for my Nexus 5. However, considering it's also near $50 in the shop android store it might also be out of the question for you. If you consider it, it's really a good charger. I think the Nexus 5 Qi charger is less, so might want to consider that as well.
    geekynerd00 likes this.
  3. #3
    Amazon.com: CHOE UPGRADED Qi Wireless Charger Charging Pad for Nexus 5, Nexus 7(2013) , Nexus 4, Lumia 920, and Other Qi-Enabled Phones and Tablets: Cell Phones & Accessories
    I just got this one and it works great even with my ridiculously thick folio case that I have on my n7. I really wasn't expecting it to work that well, but it works perfectly!
  4. #4
    I don't have personal experience with this one, but Incipio's a decent brand, and it's on sale here: DailySteals
    Here's another one for $25: DailySteals | The Heist
    And a Nokia one for $28: DailySteals | The Heist
  1. Looking for an alternative to MightyText
    By kbeakley in forum General Help and How To
    Last Post: 03-06-2014, 07:41 AM
  2. can't root Nexus 5
    By glc650 in forum Google Nexus 5
    Last Post: 01-28-2014, 04:55 PM
  3. Change default messaging app for Xolo q800
    By Kalpajeet Sonowal in forum Samsung Galaxy S4
    Last Post: 01-28-2014, 01:29 PM
