1. Dragon41673's Avatar
    I have some PDF's that have clickable links (on a computer), but when I try to tap them on my Asus Transformer TF701T in Adobe Reader...they don't take me anywhere. Is this just not a feature in the Android version of Adobe Reader...or do I not have something set properly?
    Thanks
    01-28-2014 06:01 PM
  2. sauce_a_poutine's Avatar
    Can't say, I use Adilko or Andropen office depending on the device I'm using when reading PDFs. I suggest you give either or both a whirl. Both are free on Playstore.
    01-28-2014 10:02 PM
  3. Dragon41673's Avatar
    I'll take a peek at them and see if they work. It's not a deal breaker for me, but if another program has that functionality & works as good if not better than Adobe Reader...then I'm all for it!
    01-29-2014 07:53 AM
  1. Anyone experiencing WiFi issues on Z1s?
    By Ukyo in forum Sony Xperia Z1s
    Last Post: 04-03-2016, 12:27 AM
  2. Did your Note 3 come with headphones?
    By ansa82 in forum Verizon Samsung Galaxy Note 3
    Last Post: 11-14-2014, 08:34 PM
  3. Replies: 4
    Last Post: 05-27-2014, 10:36 PM
  4. Replies: 1
    Last Post: 02-19-2014, 08:40 AM
  5. Replies: 1
    Last Post: 01-29-2014, 01:54 PM
