Hello,
I have two tablet users, first "owner" second "normal". Each user has a Google account, to both accounts is assigned same credit card. Everything works as it should, every user has its applications, email, etc.
But if I purchase any application for the account "normal", I can not run it, even if the demoversion of this application run OK. Problem is always the same (of course is changing names of the application paths and java classes), instantly after running it, there is a message:
Application "xxxxx" unfortunately stopped working.
Information from Report error -> Stack trace:
java.lang.RuntimeException: Unable to instantiate activity ComponentInfo{com.mojang.minecraft/com.mojang.minecraftpe.MainActivity}: java.lang.ClassNotFoundException: Didn't find class "com.mojang.minecraftpe.MainActivity" on path: DexPathList[[zip file "/mnt/asec/com.mojang.minecraftpe-1/pkg.apk"], nativeLibraryDirectories=[/mnt/asec/com.mojang.minecraftpe-1/lib, vendor/lib, /system/lib]]
etc.
What is essential that for the user account "owner" everything works fine!
User "normal" has allowed all mature application.
Tablet Acer Iconia A1-810
Android 4.2.2
No root, no szstem changes.
Thanks a lot,
O.
etc.
Android 4.2.2
Thanks a lot,
O.
