Results 1 to 5 of 5
    Tannis Alford's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default droid 4 phone not working
    recenltly my phone has been going crazy, last week black and white lines covered half my screen, this week i can't do anythign with my phone except use it as a MP3 PlayerClick image for larger version.
Name:	help me heretics.jpg
    the no SD card and No network symbol confuses me because my sd card has been in my phone for 3 months, and im connected to my router.
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,850 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: droid 4 phone not working
    Welcome to Android Central! Try wiping the system cache partition: https://motorola-global-portal.custh...02/action/auth
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    but not it says "NO sim card no service" the sim card has been in my phone for almost 3 months with no problems.
  4. #4
    B. Diddy's Avatar
    Posts
    Global Posts
    77,850 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Hard to know if there is some software glitch going on, or if it's a problem with the SIM. Try wiping the cache partition first. If that doesn't work, then remove the SIM and make sure there isn't any debris or other gunk messing up the contacts. If everything there looks clean, then talk to your provider about getting a new SIM card, because those things can fail.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i did what it said ont he site, now im waiting for it to activate my sim card
  1. My Phone Isn't vibrating!!!!
    By Kimberly1998 in forum Verizon LG G2
    Last Post: 01-24-2016, 09:16 PM
  2. Restoring a Nandroid backup from External SD card: Files not found?
    By Fleetknight in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 08-20-2015, 01:08 PM
  3. Will the Nexus 7 2nd gen 2013 work on my router?
    By ishimura in forum Google Nexus 7 Tablet (2013)
    Last Post: 02-04-2014, 03:53 PM
  4. Best Android phone to buy assuming a keyboard case will be purchased?
    By ingulit in forum General Help and How To
    Last Post: 01-31-2014, 11:20 PM
