I have a mytouch slide rooted and running froyo. I can't get my bluetooth headset to work with it. It will pair and connect but the audio won't go through. When I place a call I can't hear the ring or the other end pick up. The other end can't hear my either. I can select speaker and switch back and forth from speaker to bluetooth so the screen is verifying I'm connected.
And before you ask, yes I have the volume turned up on my headset. I actually have two headsets. They both worked with my g1 but act exactly the same with my slide.
Here's the wierdest part with my headset paired and connected I can hear the beep indicating when I've lost service, so the phone and headset are comunicating.
Thanks
Matthew
Thanks
Matthew
