1. chriscrasto's Avatar
    Hey guys, so I royally screwed up somehow and my G2 on Sprint is now soft bricked.
    So here's what happened: I had been running an unofficial CM 10.2 ROM on my phone and I saw that the official nightlies were available and apparently pretty stable, so I decided to try that out. I backed up what I need and went into TWRP to wipe system and I flashed the original G2 ROM so that I could update PRL before I dove into CM 11. Well, when it booted into the stock ROM, it started to download a new update which I couldn't stop and it rebooted to install it. I figured there was no harm in that, but it turns out there was because it would not install and it was stuck at 0% for a good hour, so I decided to force it to shut down, wipe the system and re-flash the unofficial CM, but it wouldn't boot.
    Everything I tried only went straight into TWRP and I have become stuck there. Well, I did the stupid thing and I advanced wiped my system and cleared the internal storage as well because I thought that might help. Now I have no backup, but it charges through the usb cable and I can ADB push files for installation. So far, all of my efforts to install and boot a ROM have not worked and I am currently in a state of TWRP limbo and can't get out.
    Is there any suggestions as to what I can do? Thanks.
    02-01-2014 03:14 PM
  2. someguy01234's Avatar
    02-01-2014 06:57 PM
  3. chriscrasto's Avatar
    That's exactly what I just did and it worked this time! I had been attempting it for the past two days but it didn't seem to update my USB drivers until I went into download mode on my phone and kept the LGMobileSupportTool program open for it to recognize and install drivers.
    Thanks a bunch
    02-01-2014 07:59 PM
  4. KING4EVR's Avatar
    How do you get the lg mobile support tool to recognoize your device. it says my adb drivers are out of date
    02-05-2014 01:05 PM
  1. How do I disable the lock screen!?
    By Topgonzo in forum HTC One M7
    Last Post: 11-28-2014, 03:25 AM
  2. what next? time for an upgrade
    By jpmciver in forum HTC EVO 4G LTE
    Last Post: 02-10-2014, 07:49 AM
  3. What power adapter comes with Nexus 7 2013, when you order from Amazon.co.uk?
    By ishimura in forum Google Nexus 7 Tablet (2013)
    Last Post: 02-03-2014, 11:58 AM
  4. How do I get the message lock screen widget?
    By LauraBunnyyy in forum General Help and How To
    Last Post: 02-01-2014, 04:43 PM
  5. Do any music identification apps email you the song you identified?
    By comptech520 in forum General News & Discussion
    Last Post: 02-01-2014, 10:14 AM
