1. mugen27's Avatar
    Hello,
    I'm looking for a used Android Phone - So many choices out there, I'm just looking for something basic and around $100.....
    Not looking for anything special, just want to have access to some apps while I'm travelling in JP. Just browsing eBay and I see the Motorola Droid X is available at a good price.. OS looks like it stopped at 2.3 though? Is this worth it for under $100?
    Any help or suggestions appreciated.
    Thanks.
    02-03-2014 11:50 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you looking for something you can use as an actual phone, or just to use wifi? A used Droid X would probably be fine if you only want to browse the web with wifi, but it'll probably be somewhat slow compared to newer devices.
    Have you considered the Moto G for $179? An excellent phone, and it's brand new. https://play.google.com/store/device...?id=moto_g_8gb
    02-03-2014 11:58 AM
  3. mugen27's Avatar
    Most likely just use it with WIFI...if I can get it unlocked and pop in a sim to use, that is just a bonus but not a necessity. I probably wouldn't be browsing much either - so if it works and I have to wait a few seconds, no big deal.
    Moto G - I'll have to take a look - a little on the high end as far as price goes......Perhaps a used one? A newer OS then 2.3 would be nice to have also......I.e 4.x
    Thanks.
    02-03-2014 12:10 PM
  4. someguy01234's Avatar
    Thanks.
    Moto G is one of the best budget phone, it has HD screen, quadcore, running latest version of android (newer than most other flagship phones), durable design, sim unlocked. It's worth spending a little more for it.
    02-03-2014 04:09 PM
  5. UJ95x's Avatar
    Thanks.
    The GSM variant is $179 brand new, while the Verizon variant is $99 brand new. If you only need it for apps and browsing the latter should be fine. Not sure about compatibility with carriers outside of the U.S. though
    02-03-2014 04:16 PM
  6. mugen27's Avatar
    I found a used Moto G for $100...In Canada...Will pick it up tonight and see how it goes. Another new toy to play with.
    Thanks for the recommendation.
    B. Diddy likes this.
    02-03-2014 04:18 PM
  7. UJ95x's Avatar
    Nice. It's a lot better than the other low cost android phones; has pretty good specs and like mentioned above, running Kit Kat, a newer OS than most of the other high end phones available
    02-03-2014 04:20 PM
  1. The phone, should you choose to accept it....
    By Golfdriver97 in forum HTC One M8
    Last Post: 02-13-2014, 08:20 PM
  2. Moto X: The camera on this phone is an absolute joke
    By el3ctronics in forum Moto X (2013)
    Last Post: 02-11-2014, 11:51 PM
  3. Replies: 2
    Last Post: 02-03-2014, 07:27 AM
